jr dragster T
Block's CAN flex a bit at 6000 RPM plus. Oscar is 100% correct. But the engine would have to be mod'd VERY VERY heavily to get block flex out of it. As long as your not going wide open no gov for like 10 minutes then you should be ok. crank shafts on the other hand DO flex quite a bit at high rpm and at high torque loads, On my junior dragster you will see a dual crank shaft support meaning it supports both flywheel and clutch.
