1990 GSX 250 manual
anderkart
Surprise Arizona USA
Now that i have wired up the start and kill switch and connected a battery the engine turns over but i have no spark
what things can cause no spark?
as according to the wiring diagram they are connected properly
I've been studying this wiring diagram: http://www.gsx-r250.com/down/suzuki_gsxr250_el_diagram_en.pdf
Your Ignition switch needs to be sending power to the (+) inputs of both Ignition coils with its Orange wire.
The black/white wire to your CDI box needs to be grounded.
There's a Black/yellow wire from your CDI box that needs to go to the negative terminal of 1 coil.
The CDI box also has a White wire that goes to the negative terminal of the other coil.
The Green/White, Black/Blue and Brown wires from your CDI box run to the Ignition pickup inside your engine.
The Orange/white wire coming from your CDI box is the output from your kill switch. This wire needs to get power for the CDI to work. The Orange/Black wire going to your kill switch is where your whole kickstand safety circuit is wired in. All this safety system seems to do is cut-off power to the Orange/Black wire that supplies power to the kill switch, so It should be fairly simple to bypass if you simply connect your kill switch directly to the ignition switch output that gets power when switched on.
I'd suggest you mount your Ignition coils and CDI box to your karts frame, just in case they require a source of ground through their mounting brackets.
tomas02
thanks for the in depth reply
but i think that is exactly how i have it wired
the kill switch is wired to the battery positive and then goes to the orange wire of the cdi
only thing i havnt done is grounding the cdi to the frame will try this today.
one other thing i thought of is if the motor isnt actually turning over with the starter motor, the signal generator wont be able to tell the cdi to send a power to the coils
because my starter motor makes a noice but not actually sure if its cranking the engine over.
how can i check its turning over?
tomas02
Got it all sorted now engine has spark and good compression and turns over
so now i will hopefully get some fuel lines tomorrow
then i can fire it up and see if it runs
