The 6.5 HP Engine on Harbor Freight???
What Engine Would You Choose?
  • Total voters
    26
tenlizard
No i mean how can you tell the amount of rpm the engine is running currently. People say that they could remove the governor for about 5000rpm. I would like to know how to measure the rpm the engine is running so i don't blow it up.
Jerryburger
Admiral Annoy
The Nation's Catbox...er, AZ.
engine rpm
Russ suggested an item called the "Tiny Tach"... its about $28 on ebay, and it hooks up very easily to most engines. That would help you dial in the proper rpm on your kart.... It has a kinda slow response time, but once you know what 5000 rpm sounds like, the ol' seat-of-the-pants takes over, anyway. Or reverse engineer the whole thing. If you know your tire diameter, gear ratio and the speeds you're hitting, you can figure your rpm that way. This is off the intended subject, though. Sorry.
oscaryu1
Yeah, a tach is the most accurate way... And probably the only way. I've heard of people making them theirselves... but I can tell you it ain't easy.
Oh... here's something:
5300RPM - Valves Float
5900-6000 - Expect the rod to go through... (that isn't good)
tenlizard
How do you identify when the valves float???
Jerryburger
Admiral Annoy
With the present gearing on my lowrider, I should be "safe" up to 52mph (5000 rpm)... I'm off the next couple of days, so I'm going to attempt a top speed run on the thing, just to see what one of these motors will do. I'll time it with the GPS and report back. The motor will be completely stock.
Russ2251
AZUSA:Powered by LAWN-BOY
Usually engine will surge up and down at the point when valves start floating. Almost resembles a high speed lean out. It's unlikely you will experience this if engine is running under a load unless you and kart are very light in weight.
Russ2251
It has been my experience that any engine (not just clones) will 'blow up' if over revved without a load.
Loads tend to smooth out combustion pulses which, among other things, causes rods and crankshafts to flex and bend. Take away the load and engine won't live very long.
This is one of the reasons that horizontal shaft engines have heavy flywheels.
Jerryburger
Admiral Annoy
Just changed the oil on the lowrider to synthetic after about 3 hours of break-in on regular oil. Came out clean and hardly any discoloration. These motors are amazing. Quite the far cry from the old 2- 3hp B/S engines I grew up with! Between these motors and the 2-stroke snowblower engines Russ found, I don't think a person can go wrong.
tenlizard
When will u post ur results? Soon?
Jerryburger
Admiral Annoy
Okay- finished a couple of runs.... it hit 47 in one direction and 49 the other, so we'll call it 48mph with my fat butt on it. Nothing weird happened, but I figure the motor didn't hit over 4700rpm, either. Posted a video under the Photo-Galleries section. Now I've got a few chores to take care of!
oscaryu1
That's what I read on 4cycle.com... although it could be something different...
Just know not to rev over 5300RPM... without better valve springs.
oscaryu1
Could you please post link where you saw this? Would appreciate it. I'll take up my argument with them. Thanx :cheers2:
Problem is, I read it around 4 months ago. Heck, I don't even remember the title name (seriously)...
I was just browsing through looking for mods (I didn't know squat back then)...
