twin disscussion
Kaptain Krunch
Pro Junk Collector
vermont
Rods dont determine stroke, cranks do. That rod will give you higher compression, but it will not increase stroke at all.
jr dragster T
Cold place
The longer rod will just increase the piston pop up. Measure how much its in the hole and how much room you have to work with first.
Rotore
Teh SPIK
Caguas, Puerto Rico
The piston is 2mm away from the head at TDC. ANd as of now it does kinda touch the head but it wont after i get all that carbon of the heads.
so would it be safe to go with a .010 longer connecting rod or should i just go with the standard size?
freakboy
the names 'mater
hick town
a .010 should be alright but you can shave the piston a bit like .05 so you get a lighter piston. just make sure the first pison ring dont come anywere closer to the deck then 1/32
jr dragster T
Cold place
If it where me I would be getting the standered sized connecting rods. You want to measure piston top to deck height with a dial indicator or something equivalent. Remember changing the rod length and nothing else affects the thrust side geometry. Just something to think about...
Rotore
Teh SPIK
Caguas, Puerto Rico
what cubic inch is that engine?
its a 44 cubic inch v twin dude here are the specs on it
Engine 4-cycle, gasoline, OHV, cast iron cylinder liner, aluminum block
Rated Horsepower 25 hp (18.64 kW) @ 3600 RPM
Displacement 44.0 cu. in. (725 cc)
Bore x Stroke 3.27 in. (83 mm) x 2.64 in. (67 mm)
Torque 39.9 ft (54.1 Nm) @ 2800
Compression Ratio 9.0:1
Oil Capacity 2.0 quarts (1.9 l)
Lubrication Full pressure w/full-flow filter
your right i should just get it running at factory specs first and then mod it.
Rickracer
RM250 Race Kart Driver
Kissimmee Fl.
A longer rod (with a piston that has the correct deck height), will be easier on the piston and make more power. IDK if .01 longer would help much though, probably not worth the trouble unless the plan is just a stronger rod, but the piston MUST match, or it will stick out of the block. :cool:
Rotore
Teh SPIK
Caguas, Puerto Rico
so who is putting their twin on what....or already put on :D
Well my kohler is poop i cleaned the block to inspect it and found huge cracks and chips in so cant its trash :mad2: will be takind off the carb, starter, oil cooler, coils and fuel pump and through it on a 18hp kohler opposed...
kazkepox
Pro- one idea to the next
Panama City, Florida
hmm, I'm not sure wether to put my briggs V on a single seat kart or a reverse trike like Irenaat made. his was basically a reverse trike racing kart lol.
