Celerity Quicksilver Sport Coupe (EA racer)
Amazon...to the rescue
Now, we have (3) layers of 1708 FG on the floorboard
I added another layer (~8"wide) across the "open" curves, ta "beef" 'em up a bit
Like here at the bottom of the seatback
And here, at the top of the seatback
And here, at the bottom of the footboard too
Looks like this...overall :thumbsup:
Early in the morning, while it was still kinda kool outside (~48*) I drew up a FG layering diagram, to help illustrate the floorboard construction
Later, in the afternoon, when it warmed up (~70*) I "popped" the FG floorboard, off the mold
But/then, I left it/put it back on the mold ta "hold it" for measurin', markin' & cuttin'
* 25"W
After measurin' & markin", I used the edge of the mold to mark a nice-n-straight line, from underneath, for cuttin'
Here is my FG cuttin' set up
** Notice that I use an oscillating cutter
...because it doesn't throw material into the air, creating a toxic cloud of FG dust, like a spinning cutter/saw would
Use a vacuum to collect dust/material, as its created
...while wearing leather gloves & safety glasses
Floorboard trimmin' pics
A straight edge & a couple of clamps helped with cutting the long straight(s)
* The straight edge & clamps helped with these short "runs" too
All trimmed up
** Notice how "clean" (no toxic white dust) I'm tryin' ta keep the work?
*** I made the mold ~28" wide
...& covered the entire width with FG cloth
So, I could then trim ~1 1/2" off of each side
...&/then, end up with a "nice" 25" wide piece
...without any inconsistent/thin spots
...&/or frayed edges ;)
Assembly method
Kinda like in automotive Uni-body construction, I'm going to use the "overlapping" panel technique
...&/so, the sides will "overlap" the "nose", "tail" & floorboard (~2")
* The "nose", "tail" & floorboard are all cut at 25" wide, to help maintain a consistent width, of everything, during assembly
...& to help "square up" the pieces, with each other too :cheers2:
First step is to prep the pieces by "scuffing up" (~2") along the outside edges of the "nose", "tail" & floorboard
...&/also, (~2") inside the perimeter of the sides
* I pre-assembled the pieces (to ensure fitment)
...& used screws to "bolt" 'em together :thumbsup:
A sneak peek at construction ;)
