ST2-NG Pre-build "Think Tank"
There's a formula to adjust to a lower setting or you put the torque wrench 90⁰ to the adapter and the amount does not change. If the amount is 180ft/lbs, you drop it to 155ft/lbs and you'll achieve the torque spec. Since the cylinders get torque to either 15ft/lbs (I think have to look it up again) or 13ft/lbs, long as I have room, should be fine.
Cylinder hone showed up yesterday. Any recommendations for a honing oil? Evidently the company I got the hone from, also has like a 1 gallon jug of their own oil for sale on Amazon. Thing is, I may need like maybe a quart to a half gallon tops to do both cylinders.
Staff Murderator
Buy it, unless it’s redickerously expensive. Buy it anyway. Otherwise, seen people using any oil even WD.
When I worked for Buick I would use ATF in a squirter oil can. You don’t need to soak it just keep it wet. Soak the stones for a half a day or so before you use the hone.
Staff Murderator
Soaking the stones is next level brainery. Nice one, Denny. Same for the ball hones as well or are those not recommended? I was trying to think of ATF (it’s like the perfect consistency too).
Same with the dingle ball hones, used to soak those too. When done with them I’d put them back into the ATF and soak them to clean the stones.
Surprisingly, unless I go to maybe Tractor Supply or possibly Wal-Mart, Kerosene is not very common out here. In Minnesota, Fleet Farm had at least 1 pump, maybe 2 where you could fill up a can with Kerosene. Out here in Nebraska, haven't seen anything.
Will keep it in mind though. I might have 1 bottle of Mercon LV sitting in the garage, not open.
Proffessor of Junkology
Lamp oil is kerosine also, and you get a nice citronella scent. Here on the left coast even hardware stores carry it. #1 diesel is the same stuff purdy much.
Smoking while honing is not recommended.
Hours are getting low again. Been adding parts to my DK cart so I can do an order. Looking at finding 2 VM32mm Mikunis for this, so I can go the dual carb instead of the single 34mm feeding two cylinders. Once I can finally sit down and work on the engine, I'll probably open a second thread, leave this thread open as the main spitballing thread, then open just the complete buggy build thread. I'll throw in the URLs in each thread so others can jump back and forth, and see the insanity that has been going through my head for years.
I am notoriously bad at staying consistent and changing my mind every few minutes. I'll also need to redo the drawings for some of the parts in CAD to get stuff sent off to have it cut.
Will have to order the bearing flange kit from Azusa Engineering, because, far as I can see on GoPowerSports website, the only carry for 1" live axles and not for 1-1/4" at the moment.
