Offroad big block buggy
Eztrail
Cleburne, Tx
And had to make a stud to mount the valve cover. The mounting boss is off center so I had to grind the thread off 1 side of the stud to clear the rocker trunion. This is a before pic. Sorry didnt get an after.20260511_152644.jpg
Eztrail
Cleburne, Tx
Battery box done. Exhaust is almost done. Had to make a new exhaust flange. Need to buy an exhaust hanger and springs & hooks for a slip joint in the middle. Carb and tank are just sitting there.20260513_200933.jpg
Eztrail
Cleburne, Tx
Small but hope its sufficient. I had this build in a 200lb heavier utility sxs and it performed well. Only difference is ive added the 1.3 rockers. So less weight and more power, I hope I'm good. If not I have a vangaurd 570cc I can swap into it.
Yeah thats where i've been looking. I always wonder about quailty, given the source.
The last few things l got from ebay have actually been decent quality.
Eztrail
Cleburne, Tx
The aluminum is thin. I was concerned that it wouldn't hold up, but its been fine so far. Better option would be to buy a USA made tank. Also the spun aluminum was soo rough i was worried someone would get a sliver by rubbing it. So I sanded down the surface some.
Doesn't sound so attractive now. Still half price of a USA made cell.
I've had problems with leaky caps, or caps that are a fight to get open or closed.
l'm like'n the old school 1/2 turn cap or the threaded pipe caps.
I ordered a fuel tank like yours. You called it right. Purdy rough, but I am especially fond of the weld patches, kinda in the middle. Still for the price it aint bad. I'm gonna weld a block on it to accommodate a fitting for a return and vent line. Purdy thin stuff, this may not go well.
