Diamonite Electrathon America Racer
Notice how cuttin' is so much easier, when workin' with smaller pieces :thumbsup:
Ta make the rear "deck" I had ta cut/trim out, around where the seat goes
With the "sponces" in place
...the rear "deck" panel
...& seat installed
...it kinda looks like this ;)
Another view
Nice-n-tight "fit" :2guns:
Rough drawin' of the cockpit area (w/modification/concepts)
Simply flipped over...for better context/understandin' ta make the "plug"
Drawin's w/measurements of the various inner "ribs"
Top view of "plug" (in the rough)
Another view
To use as "fillet" material, I cut a 45* angle. off of a piece of 1/2" MDF
...& then, cut the 45* piece off
...so, I had some 1/2" x 1/2" x 1/2" triangular type material ta work with
...& used some ta "fill in" & "round off" this area
Another view
Been workin' on the "ends" (nose & tail) ;)
Addin' some "guide lines"
Front/Nose "guide lines"
Tunnel outlet "parts" (flange & beginning of the tunnel)
Tunnel outlet flange assembly
Tunnel outlet flange(s) "mocked up" :thumbsup:
*FYI: this "mock up" is just for illustration purposes
...as they are currently inverted :innocent: (as in upside down) :devil2:
Cut a bunch more "flange" material(s)
Ta help "round off" the inside corners, like these
Notice, them "fillets"
...are kinda like floor trim
...around the perimeter
Helping ta "round the corner"
...& "sealing off" the (horizontal panel to vertical panel) junction ;)
* Except...your lookin' at the top
...NOT the bottom/floor :p
Someone in the back says: :smartass:
"Seems to be getting...kind of complicated/"boxed in"...back there
...how you going to get the "piece" out of the mold?"
Well, I'ma glad you asked :thumbsup:
I designed the rear section, of the mold, to be removable ;)
Jualla :2guns:
Rear section of the mold
...with tunnel flanges :wai:
Separated from the "main" mold
...still "technically" inverted
Un-inverted
...or maybe verted :smartass:
* Notice the nice ~2" "lip"
...that we should "get"
...along the bottom
The ~2" "wrap around" flanges
...along the sides
How they should
1.) help "stiffen" the "tail" of this chassis/monocoque
2.) produce nice "connecting flanges" for mounting the "outer" body (side & floor) panels :thumbsup:
Close up of some of the "trim" work or "fillets"
...that are "bridging" the horizontal to vertical transitions :cornut:
An even closer
...upper closer looker ;)
Frontal air intake (parts/sections)
Frontal air intake w/built-in side flanges
Frontal air intake installed kinda looks like this
Another view of the frontal air intake w/top & bottom flanges
One more view, of the frontal air intake, for mor better reference ;)
Removable "lid" (on right)
...for the "nose" section
...w/flanges
"Nose" section w/lid installed
Close up view of
...the "lid" flange
...to ~1" "face" (of the "nose")
...to air intake flange :thumbsup:
In-verted "nose" section
Verted (technical term) "nose" section ;)
Happy 420 you'all :cool: :2guns::cheers2:
Back ta workin' on the "main" section(s)
Got the rest of the perimeter flanges installed
...& all associated fillets :thumbsup:
Another view
Added some strategically placed holes
Another view (from the bottom side & without the cockpit "hump")
*Notice the "underbelly" access port?
Also, been doin' some bodywork :thumbsup:
Applied some wood filler to help "fillet" some areas
...& fill-in any gaps or imperfections
Then, did some sandin' (smoothin' & roundin')
Close up view of a "roughed in" fillet (just used my finger)
Close up view of a "rounded" fillet (after sanding) ;)
Schmoosin' the quality control inspector "Ducky"
...durin' a quick brake :cornut:
