Streaker gokart refresh
Thepartsguy
I thought I had a thread on this but I guess not.
The very first ever streaker I ever purchased with the big proud to be an American flag on it has been completely torn down stripped then painted.
It will get all new hardware and bearings anything that can be new will be. Waiting on parts now and I’ll update as it gets put back together.
Then I have to start the pain staking task of doing this all over again to the other one with the blue kohler.
IMG_1930.jpegIMG_6125.pngIMG_6128.pngIMG_6323.jpegIMG_6324.jpegIMG_6328.jpegIMG_6329.jpegIMG_6123.png
Neat seeing that giant Kohler on there. I know next to nothing about them, can you give us a rundown?
Thepartsguy
319cc and these things just don’t die….
The engines themselves are massive cast iron 8hp k181s models and they come on wheelhorse tractors. I bolted the wheelhorse engine mount to the streaker engine mount so I could mount the engine up to the stock 5hp plate.
The eBay header and vm22 bolt on with the stock kohler bolts no drilling out any mount patterns or having to weld an intake together.
I couldn’t imagine the power these would make freshened up 30 over.. They make great power even all wore out.
IMG_4106.pngIMG_6334.jpegIMG_3415.jpegIMG_3413.jpegIMG_3414.jpegIMG_3857.jpegIMG_6335.jpegIMG_6336.jpegIMG_4122.jpeg
Thepartsguy
The seat is in bad shape but it’s the only high back tractor seat I have. All parts are ordered painted or just in general ready to go.
No more pictures needed until the 26th when the sprocket shows up in the mail and I can fully assemble and finish this refresh up.
Then to tear down the other streaker and start this process all over again.
Wish I could sew vinyl, because the Ken-Bar seat cushions are simpler than most, even with the white stripe. They are a slip-on cushion design and there's an extra layer of vinyl on the upper part, a sleeve, that slips over the top of the metal seat back. Seems easy peasy but another rabbit hole to go down... and get bogged with.
Thepartsguy
I have to bolt the fuel pump to the torque converter plate and run new fuel lines.
The torque converter backing plate has to be removed real quick so I can install the new points.
Then I can bolt on the new 30 series and I’m still waiting for bearings and 5/8 axle spacers for the front in the mail.
Thepartsguy
15 amp voltage regulator installed throttle connected and I put a new set of points on the kohler.
Waiting on wheel bearings and spacers for the front. I have to go buy some chain. Hook up the very simple wiring and lastly bolt the fuel pump to the backing plate and run new fuel line.
Once all that is finished up back to street racing!
Off topic but I made mine for my Streaker the easy way. Take a look on my build thread for it if you're interested. Not perfect but it's nice enough.
Thepartsguy
To finish this up we ran maybe 15 or so miles today. Hassle free the whole ride. It was 81 degrees and sunny MOST of the day.
On to finishing up new projects.
Thepartsguy
To be sure, the kart does not have extreme toe-out on the front wheels, right? 😵
I promise the camera angles are playing tricks. The wheels do not toe-out like that. The wheel is slightly turned to the left and these things have EXTREMELY heavy Ackerman steering.
Steering these with locked 1” live axle is easy and takes ZERO effort. You would hop in it and swear it’s just an open diff. It’s because they designed the steering so well.
The way I can explain it is when the wheel is straight the tires are straight. But when the wheel is turned HEAVY Ackerman activates nearly instantly. It just make the wheels look funky
Thepartsguy
The zipties oh the horror! Anyways the points wire was hanging on by 2 strands of wire and I wondered why the engine was struggling.
New points and wire and everything else and it has power again. Ready for street racing!
What's the story on the factory fuel tank location? Was it bolted to the top or hanging off the side from a few cylinder head bolts?
What's the story on that forlorn looking CJ-5 in the background?
Thepartsguy
On the kohlers it had the tank held on a bracket to the head bolts and two bolts to the front shroud. Also if there wasn’t the revision in the shroud for the top tank mount they would just use a remote tank and the cam driven fuel pump.
A guy local had a bunch of cheap Chevy v8’s and the 258 was cracked nearly in half after it froze but somehow ran fine. Me and dad had a bunch of fun with the chevys. I’ll find my OG post of the sticker price I payed for the white heritage tiger top made with stock of OG leather from the factory left over from the 70’s I think it was around $1,300
Atlanta, GA
True story: My father bought a CJ-5 in the 80's with a 350 SB and a wild AF cam in it, it would barely idle. He engine swapped it with a Gremlin, put the AMC straight 6 in it. Then he painted it with house paint. Most bat-sh!t Jeep story ever.
