Proffessor of Junkology
Thanks. I'm getting ideas together for same area on my junk.
My wedding ring is titanium, those "little balls" (weld splatter) stick to it like glue.Thanks but getting thoes little balls that I need to sand off. Both pieces of metal were bare and clean. Plenty of gas, doors closed so I didnt have a cross wind. And I snip the wire clean before I start. O well
Let me make sure I heard this right. You are going to mount a Duramax on this frame?Today decided to bring the kart in the garage. We ended up yanking the motor. View attachment 152242
DurO...Let me make sure I heard this right. You are going to mount a Duramax on this frame?
Are you bending the tubes yourself and if so, is it a hydraulic or manual bender and how do you get them so symmetrical?Ok so I was able to get out in the garage today for a little bit. Bent up a rear bar and got the top joint mostly fitted. A little more tweaking and it'll be ready to tack in.View attachment 159616
Sorry - Is this the Duromax from the Chevy trucks?DurO...
