DONGFANG DF200GKD Gokart help???
Richard K.
Ha All! Thank you for all the help My DF200GKA is fixed for Now It was a Coil that was the trouble It wouldn't run It would only Idle
I changed it out and It runs for Know.
Thanks All,
warrior5delta
I emailed DongFang and asked for a wire diagram for the DF200gka, here it is for anyone that needs or wants
Dang
New York
Just curious, what did you find wrong? I have a DF200GKD that I built for my grandson 6 years ago, when he was 13. After he got his license and a truck, it's been parked for 3 years so I've brought it back home to fix. I've got power at the dash when I turn the key, all lights work, but I have to jump it at the solenoid. I replaced the ignition switch and the solenoid, but when I turn the key, it's still "zip". I've been all over this thing with my tester and can't identify any faulty wires. I thought maybe you found something I've overlooked.
Man I have been on here in awhile just not read this haha. I replace the key ignition switch just end up making a switch to jump the solenoid to start never figure out where that black wire attach to. I think that wire suppose to make a connection when the brake pedal are press down and you turn the key to make contact to the solenoid to supply power to the solenoid.
Ronald
Abbeville LaP
Good afternoon
I appreciate y'all accepting me in y'all group.
One of the reasons I joined is because I purchased a second hand Dong Fang 4 seater go cart for my 3 grandchildren.
I have had some issues with it but nothing major. First the battery is not being charged. Therefore I want to change the voltage regulator first. I did check all the wiring and replaced the ignition switch. The problem I'm having is to find the correct regulator.
The model is DF200GKD and the vin number is LXDACLAC8H1051449
Attached are pictures of the regulator and tag from the go cart.
If anyone can help me with finding another regulator or trouble shoot the charging system for me It would be deeply appreciated
Try here.
You want a 6 wire 2 plug rectifier.
Then match to what version you have.
Good old china.
Do the colors go to the same pins?
Ive seen entire harnesses wired correctly but the wrong colors. And vice versa.
Follow the wire not the color code so to say.
Ronald
Abbeville LaP
Good old China.
I've seen entire harnesses wired correctly but the wrong colors. And vice versa.
Yep that's China for ya
The color order of wires on the new reg do not go to the same pins as the old one. I would have to change the order of the wires to match the pins old reg.
Ronald
Abbeville LaP
Good old China.
I didnt answer your comment, do the colors go to the same pins? Yes the colors on the new one goes to the same pins as the old one. They do not go in the same order on the regulator.
Ronald
Abbeville LaP
Hope you dont let the smoke out. Its hard to put back in.
Well it worked out perfect Battery charging and Kids are riding. Engine starts and runs awesome. I cant thank you enough for helping and if you ever need anything from me just let me know. Also if you ever make it to Louisiana give me a call. We will show y'all a great time.
