Who thinks they can help?
Atlanta, GA
Well part #62 ain't a belt. I don't know who's drunk. #67 is a belt or a circular snake of some kind.
Is it a real CVT or just a rudimentary "gear reduction"? Never seen one configured with just 1 variable sheave pulley and 1 fixed pulley. Why not just use a jackshaft? Just wanted some theorizing.
Thanks Karttekkk, but I already understand a centrifugal clutch.
Karttekk
Elizabeth, PA
That was a useless link. I was hoping they would shed some light on the advantage of a belt driven centrifugal clutch. Easier to replace a belt instead of messing with chain links and stretched chains. Lower powered engines are probably okay with that setup.
Goldwinger
Adams, NY
So far I have been unable to pull the pulley off. The jack shaft was seized up. Got it to move but not freely. Looks like I may have to replace it.
Follow up on the jack shaft - it’s junk. I’m planning on replacing it with a chain and sprocket. The drive wheel has a 60T sprocket. What size sprocket is recommended for the engine side of the jack shaft?
Is the smaller sprocket indeed a 12T?
This Speed Calculator can help as you can "enable jackshaft" and put in the values (teeth count) that will get you the speed you want.
https://www.gokartguide.com/gear-ratio-chart-speed-calculator/
