Who thinks they can help?
Goldwinger
Adams, NY
I just picked this up for $100, but I don’t know what I have. Possibilities?
Egad, what excellent photos bro. Not one, not two, but seven pics.
No one can help you now. That is an old Carter.
Seconded. An oldie but goodie 'Murican-made Carter Brothers go kart (made in Alabammy).
Looks like "Bubba" did some modifying. Changed the steering wheel position to the middle (it's a 2-seater kart) and at a radical vertical angle looks like, but didn't change the pedal locations to fit. He musta been a fatäśś.... 😄 That big spoked belt pulley looks non-standard too. $100 is not too bad for a roller with 4 good-ish looking tires. It looks like a Kart Wheels® K2745 https://www.bmikarts.com/PDF/Carter-Bros/Model k2745/k2745.pdf
A one-wheel-peel kart that had a torque converter?
Karttekk
Elizabeth, PA
They actually had a live axle. Needed keys on both ends of the axle.
You're WRONG! 😄 Look again closely at his pics. That's not what he has, he has a square solid axle not the hollow tube with the bearings on the ends (which I'll add is super genius and safe for long hair, fingers etc).
Karttekk
Elizabeth, PA
You are correct sir. That is definitely a "one wheel peel" machine. I should have said "some models" shipped with a live axle. Thanks for clarifying.
Goldwinger
Adams, NY
Another "modification" was a welded on nut for the drive wheel bolt to be threaded into.
The parts list I linked in post #5 appears to have a solid, non variable pulley on the driven part of the assembly (part 68), according to the part description: Part #68 "G566 Pulley B5 3/4" w/ 3/4" Bore".
Part #62 is "G704 Centrifugal Belt Clutch" and can be found by on a web search by part number. I thought this was just a Series 20 torque converter/CVT but it appears not. Can anyone explain this?
