lawn boy power
karl
North east Ohio
Anytime!
We have fuel, motors is mounted, it runs well.
Just need to aquire shim stock to fit the rear axle .
karl
North east Ohio
I done used another solution
karl
North east Ohio
Love me 106.
Sidecar with lawnchair? May build another for that.
Got it close enough to test ride. Rear fender puts in work . Need a 1in brake lever
karl
North east Ohio
It's got the torque and gearing lol. The carb is very responsive, perfect for a stock flathead
Grips showed up and actually fit. both are 25mm (1") . $7 on amazon .
karl
North east Ohio
I can lend you my immoral support?
What should I stencil on the belt cover/ fender?
Also check this toggle , haven't seen one with a full condem
karl
North east Ohio
I had to shorten that.
Kill switch operational, and you always have the backup ziptie on the lead.
I learned from past snowbike experience, that the carbs like to ice up on the 5hps, and carbs
with external linkages stick open, so Im hoping the slide carb prevents all that. Really need
to tape up the blower housing some or make a more elaborate solution to direct hot air over
the carb.
karl
North east Ohio
Need more long 5/8 bolts. But the frames all bent. Just 2 more for the handlebars.
30' of 1/2in black pipe is being used for the construction.
Was trying to build the pop mechanics tom thumb bike
but Its turned out too big. Still gonna be 2 cycle. And it
is still quite small.
karl
North east Ohio
Proper DIY here
karl
North east Ohio
Thanks !
I already lied. Was at that place, and had $25 off.
Well I still could go another route but its looking like a good fit.
Also hope the head tubes straight, passes eyeball check
Check out the very scientific jig I used.
karl
North east Ohio
What, is the 3.5 fl/lbs of the 79cc pred not thrilling enough?
Briggs 5hp muffler, and 3d printed an air filter adapter.
