You missed a .0,Dove in to inspect; the PVL did not want to come off and required negotiations with a torch and oil before it let go politely.
Piston checks at precisely 0.10" in the hole with a big ole exhaust relief cast into the crown. It's deep enough into the dish Im not even sure an FT swap would be safe having to cut that deep.
That said I don't think I'm going to change anything but the exhaust, probably the carb at some point... the whole damn head would have to swap to run an FT so I'd go 18cc there because 14 just seems like a high comp problem
Q: Does the PVL use a specific coil?
Im not going to use it due to the lack of charging support, So if I sell then I'd prefer to include the coil.
Yeah I did... used the back edge of a new hacksaw blade to bridge the cylinder and stuck a feeler under it until one fit 0.010You missed a .0,![]()
Most of the clowns I know swear by a Predator and wouldn't know what a Ducar is if I tried to stick up their arse running.No worries, I know it's only .010"-.015"... it's a Ducar. I've been inside a few,.
Don't punish and cuss the flywheel, it's built and designed to be removed and re used with a FLYWHEEL PULLER. It's not a stock over weight p.o.s flywheel. No hammering on the crank, no prying on the flywheel and block with a crow bar.
This is a quality "turd motor", not some junk roto-tiller motor anybody can buy at HF and really think they got a deal on a race motor![]()
Nah, but I've got a lot of practice knocking them off "the wrong way" so I can pull the aluminum ones without trashing them.I hope you didn't fruk that flywheel up, that's the twig and berries of that bad boy,![]()
27/24 at a steeper angle but I didn't expect a shallow dish with a relief, there must be some serious lift on the cam.That's the same piston that comes in all the Ducar 212's, it needs that exhaust valve relief, cas........it's a HEMI !!!!!
The edge of the exhaust valve is the closest to the piston. Told ya.....it's a different HEMI head then the pred.![]()
My Dover is currently on my 208, but seeing as this thing is capable of turning over 5k on it current coil that's what I needed to know.The pvl flywheel works with any clone style coil, save your Dover coil for your build.
To quote one of the guys... "Its a what? Who makes that?"
A little oil
A little heat around the shaft but not on it
A little more oil
Thread the nut on, slide a tire iron behind the flywheel, and slap the shaft end square with a flat faced hammer. The heat, oil, and resonant vibration through the crank does more than the tire iron because that's only in play to control movement on the work bench.
"Twig and Berries"It's going to be a Burly Eunich then because the PVL is of no realistic use to me
Sell the PVL, keep the coil
I know, wanting the Ducar was about getting quality. He had 2 untouched Predator Hemi's for a Benji each if I wanted a janky B*tch engine that would need 3x the work to be what I want and still DNF on the quality.
Jus a heads up, when you put those charging coils on and add that much heavier flywheel, you completely changed what that engine was built and designed for.
That's fine. If I can set up the 24/36vDC motor I have as an external alternator then I have no reason to put on a pig puck flywheel. Make me no difference either way because again I DONT DO TRACK TOYSIt's still gonna have the torq and hp, it's jus not gonna come in as quick as it would with the much lighter PVL flywheel.
If I swapped the carb I'd no doubt go with a PWK design because I already have plenty of both jets for those. I'd very likely get a 26 and swap it in for the 24 on my 208 currently despite being beautifully dialed in to that engine and cam.Don't add a bigger carb, it'll jus make power come in later.
Not going to run any stock boxes.That ruixing comes from the factory with a .016" low speed jet and a .028" main jet, the e-tube is nothing special.
You can easily open the main up to .031" with a 1/32" drill bit.
The low speed needs opened too, but you gonna need a .018" then a .020", then a .022" to creep up on it. Go too far on the low side and it's gonna hunt for a idle.
With a ruixing carb, stock air box and stock muffler, I start with a .022" low, and .031" main, but I have extra jets, sprockets, driver springs and weights, if I go too far, I can change back without being stuck with a mistake.
I'm really undecided on the FT & Wedge Swap, but mostly my focus is going to be getting the running gear squared up.
I'll likely throw a velocity stack on the ruixing, with a round brigs filter strapped over (paper torched out, prefilter only) for the time being and I have an exhaust already made that should work fine (1" ID straight after clearance for the studs)
The extra flow from that combination should lean it out just enough to be perfectly on point based on how black the Autolite plug is.
I also pulled it apart due to improper transportation on the sellers end. He apparently filled the tank to the too and let it run it a bit before bringing it; unfortunately the petcock was left open and it took a tumble in the bed of his truck before being restrained... no harm, no foul, just a completely full lower airbox and cylinder of gas from near BDC
With no load it will bounce off the gov pretty quick.Got it started and holy crap does it shudder a lot.
I adjusted the fuel screw (it was basically all the way out) a bit and got it to even out.
If the governor doesn't stop being erratic, that POS is coming tha fuq out! I will not tolerate the herky jerky open and shut bullsh!t it's doing for too many more tries to get precise throttle response across all ranges... so I need some input.
The straight pipe I tossed together is loud AF but sounds so mean too... I almost hate saying I love how it sounds just because where I am that thing would be heard from 2mi away no problem
Figures unloaded is the issue. I don't have a meter in it so no telling, rough guess it's just off idle.With no load it will bounce off the gov pretty quick.
With a load, it wont be bouncing off the gov til its around 5300.
I agree, its more aggressive then a stock tiller engine governor, but still very tunable.
What rpm are you seeing this at ???
The autolite 3910x is a cold non resistor plug.Figures unloaded is the issue. I don't have a meter in it so no telling, rough guess it's just off idle.
If I manually restrain the governor arm I can tell you there's a sudden power drop right around half throttle but give it a second to push through and it jumps hard after 3/4.
It has one of those stupid autolite cross plugs which I fully intend to swap for an NGK after I cross reference the heat range for an AR 3910X FXcking resistor plugs
I've got a BP8ES in my 208 which I need to get more of anyway, dropped and broke one, so I had to grab my spare already.The autolite 3910x is a cold non resistor plug.
Start out with a ngk 7 or 8, resistor or non for testing and finding bugs. I think it came with a 7 resistor from the factory.
I follow standard procedure,With the low speed mix screw 2-3 full turns from seated, will be the best , that's what I see anyway.
I put it back together exactly as I received it minus the airbox and exhaust... I don't have the parts to play with at this time and I wanted to hear it sing as well as see how gnarly yanking it's tail would be since my 208 damn near dislocated my shoulder (even with gently hunting for the compression stroke first)If it runs best (snappy hole shot) more then 3 full turns out, it needs a bigger low speed jet.
If it run best, less then 2 full turns out, it needs a smaller low speed jet.
That long tube header will need some extra turning, but I'm sure you will figure it out.
You still got the pvl or swapped over to the starter flywheel ???
Heat up the engine,
set a higjer idle than normal.
Soft seat, and back out by 2 full before it stalls
Count additional turns out until the rpm stops climbing
Turn back in by 1/4 turn
if over 3 increase pilot size by one and start over
if under 2 reduce pilot size by 1 and start over
as is it seems to favor 2.5 turns out
It won't start without the choke closed, but once it fires and catches it's breath gotta flip it open or I'd will shudder like all hell trying not to stall; so like it better be open in 10 seconds or less
There's the pipe, lol. What does the color say? I rubbed it with 400G after welding and grinding so it started from a semi-shiny uniform color (minus the tip and there's a 3 tack unfinished weld down that way)
I know lol, the flange turned a little blue but nothing like the bottom 45Β° bend which actually has some purple in it.![]()
dang that sucka is looonnnggg!!!
Looks fine too me, the color is jus hot spots from the heat building up in the turns.
Are you referring to the "Split" in the magnet or something else?If the color was right after the flange, it would be too lean.
The pvl is easy to check ignition timing on. It has a line on it you use to find what * it is btdc.
I've got a couple piston stops made from spark plugs, but my "quick and dirty" is drop a 3/8x6 extension down the spark hole and depending on how much it drops turn the engine and try again until I can "wiggle out" TDC based on the extension movement.If you got a degree wheel and pointer, I can walk you thur it the "quick and dirty way". No need to take the head off.
I'm not doing anything until I change the gas uhhm... well it was oilAll mine start without choke.
Try this
No throttle
Ignition off
Choke on
Give it a couple short chug, chug pulls, jus to get stuff moving
Turn choke off
Turn ignition on
No throttle
Now give er yank.
The bigger the low speed jet, the easier they start. But too big will load up on you at idle, puff a lil black smoke but sounds like it's gotta nasty cam.![]()
My 208 will hold an idle at 2150 Β± 50 without load up.I keep mine idling 2000-2200 so they don't load up with fuel so quick..
Yea, it's that notch. All pvl and newer arc's have it.I know lol, the flange turned a little blue but nothing like the bottom 45Β° bend which actually has some purple in it.
Thats it, between the magnets. It usally gets filled with dirt and grim, but it is a slot.
The coil is whatever Dynocams put on it, since I had it off and their recommendation is 038-040 I set it to 039 using 2 different blades on my feeler set in unisonThats it, between the magnets. It usally gets filled with dirt and grim, but it is a slot.
I started out using a popsicle stick in it, then roll the flywheel back til it hit the coil leg.
Set the coil air gap .045-.050" with the pvl, it's got hotter magnets in it and will fry a coil, if it's too close.
I set my pvl .065" with Dover coils.
.075" with ARC flywheels.
.035" with stock flywheel magnets.
The coil is jus stock, nothing special. Its probably got a 168f on it somewheres.The coil is whatever Dynocams put on it, since I had it off and their recommendation is 038-040 I set it to 039 using 2 different blades on my feeler set in unisonit doesn't have bigger than 035
I did do a bowl swap when I checked the main jet size (030) so it's got a deeper bowl... that shouldn't be an issue but idk maybe it is
I noticed everything on this engine has a Lazer etched number crankshaft included.
