Was wondering if anyone had any manuals on this? New carb and gaskets and air filter changed the oil. The governor and throttle linkage springs were missing so not real sure how complicated or important they are but just had them rigged to get it goin. I had it runnin but it had no power but sounded good. All of a sudden it died with a pop and now won’t even try! Checked spark thought maybe it was weak changed the coil, nothin. Starter fluid in the carb throat and spark plug chamber does nothing. Fairly new spark plug looks clean a little wet when I pull it. Had the carb off and cleaned multiple times. Didn’t leak down test but did do a compression check had around 90 at 5-10 pulls. I’m bout to tear it apart and check rings, valves and maybe head gasket? Any thoughts? Thanks in advance
