It's still lean on the low and high side.
Plug gap .027"-.030"
You can move the needle and adjust the low speed mix screw to help the low side.
When the ground strap is blistered white, it's over heating the combustion chamber, more fuel will cool it down and start changing the plug color.
A hotter plug will make it more white.
When you moved that spring, it goes into high sooner, You should see a big increase in mph, until it's outta the powerband, the mph will still go up, but not as fast.
Where do you think the powerband it's at now, peak torq and peak hp????
This 1 seems to me, to be at 3600-5200, but it's still got the stock air box and carb. After 5200, it noses over, mph still goes up, it's jus alot slower going up.
This 1 rips outta the hole like a phat girl at a buffet during closing,
But I use the regular 30 series driver and got 3000 rpm stall springs it.
I'd say the front tires would be off the ground with 3600 rpm springs. And that would make it really hard to handle on the trails.
Keep tuning, you will find that sweet spot.
