Thepartsguy
- Messages
- 1,427
- Reaction score
- 1,283
What size are your tires I have split rims and might have some open wheel hubs.
They're tiny little things. 4.10 x 3.50 -5What size are your tires I have split rims and might have some open wheel hubs.
I've got a new one wheel peel thing installed right now (wheel) but I very much appreciate the offer.I just shipped a bunch of stuff out been using $17 flat rate boxes but know there’s smaller ones up on the post office rack that are hopefully wayy cheaper. do you need a 5” split rim? or do you just need the hub?
@BrownStainRacing I was just riding around a parking lot behind my house (have to drag it through the woods cuz one wheel peel cant pull in dirt for nothin, extremely tedious task but very much worth it) doing some drifting and what not. Dude... This thing blows my worn out 5hp briggs out the water. It maintains rpm while drifting soooo nicely. So much acceleration, pretty good speed. This thing is awesome. It's so much fun to actually be able to drive it around turns and stuff and go fast at the parking lot without my dad yelling at me, and without constant fear of my neighbors calling the cops on me.
Curiosity gets the best of me though, if I bought a cam/valve springs/rod could I unlock even more torque? I wanna drive it around with my friend and still be able to haul.
Hmmm are you saying a cam is too much for the lil one wheel peel?![]()
I'm glad you're happy with it.
I've said so many times, it dont take much to get these "turd motors" to wake up.
I can't recommend a cam for you , RIGHT NOW, it'll jus blow your tire off.
But.... I can recommend you to shim those valve springs.
Even tho they are stock springs, when springs are set at the correct installed height, they work much, much better.
Another thing that you can do is port that head.
Save your penny's for a dremal and learn how to do it CORRECTLY.
You will be shocked what a lil head port work can do to these ol' turd motors.
A bored stock apperaing carb will light it up for you, but not without shimming those stock valve springs 1st.
Take a look at these springs, they ALL have a certain installed height or a @ #. It most definitely matters.
Racing Cams and Parts | CLAM-SPRINGS | Precision Valve Springs at DynoCams | DynoCams
Explore CLAM-SPRINGS at DynoCams for precision valve springs designed to optimize engine performance. Our high-quality springs ensure reliability and enhanced horsepower. Order now for top-notch engine solutions.www.dynocams.com
It's spring installed height that makes the difference. It makes the spring what it should be.Hmmm are you saying a cam is too much for the lil one wheel peel?
I have a dremal (my dad does at least lol), its the micro cordless. I have a lil motorized bike and always wanted to do some port work on it, but was always too scared I'd mess up my port timing. God is that thing slow compared to this go kart.
What kind of shim would I have to get? What's the idea behind a shim? To let it get closer to coil bind and therefore more tension?
I bought a 18 tooth Chinese clutch off of amazon for experimentation purposes. Wow! Scary fast@Chiron TL-34
This will help you gear ratio, you can change the clutch sprocket and not worry about changing the wheel sprocket.
A good quality clutch and parts are plenty available.
Thread 'Hilliard clutch' https://4cycle.com/karting/threads/hilliard-clutch.131820/
The clutch is kinda junk though, and I don't really wanna go that fast on that crappy brake. I'm gonna put that 12 tooth MaxTorque back on tomorrow so I can feel that awesome acceleration again.
I run it.I saw on OMB warehouse this alleged performance spark plug and saw it was half off on amazon so I bought it.
Do you have any experience with the Autolite AR3910X? Is it any better than my stock Torch plug?
That damn 3910x race plug!!!!!How did my crank go before my rod!?
Exactly like you said. I was doing donuts on my one wheel peel when I noticed it was knocking really bad. I immediately turned it off and when I tried to slowly pull it, it just wouldn't move at all. Took the engine apart and boom, broken crankshaft.That damn 3910x race plug!!!!!![]()
My best guess, if you still running that 1 wheel peel kart.
Doing left hand donuts in a tight circle, then turning hard to the right on asphalt or concrete.
That tire and crank is spinning fast, then all of a sudden it's slows down almost to a stop when that tire gets hooked, that cam dont want to slow down.
I see more cranks snap in half on mini bikes when people start jumping them.
Too much wheel speed, then almost a complete stop, that's hard on every thing.
What was you doing when it stopped?????
We live and learn, young fella.Exactly like you said. I was doing donuts on my one wheel peel when I noticed it was knocking really bad. I immediately turned it off and when I tried to slowly pull it, it just wouldn't move at all. Took the engine apart and boom, broken crankshaft.
Get both beads broke loose.Remember when I got the go power sports 5" drive wheel assembly? gopowersports
I've been trying to replace the tire on that thing, but I just can't for the life of get the new tire actually on the rim at all.
Do you have any tips for replacing tires??
