BrownStainRacing
- Messages
- 1,367
- Reaction score
- 1,486
Man, I'm having NO LUCK finding that ft piston for you.Damn that thing is nice, I see the burnout marks haha. I might just order a stock piston if I can find one and that head
I've built a ton of these clone engines and always try to keep the clone sizes. Crank pin, cam journals, wrist pin, crank/flywheel taper, the same clone size, that way if something happens to the build or customer wants a different size engine, the billet parts can easily be swapped over.
You could use the stock dished piston and get a 14cc head to bump up the compression ratio.
The 14cc head uses smaller valves (25mm intake, 24mm exhaust) but with that big compression bump, you will never feel the small valves,
I never used a 14cc head on a 224, but it makes a stock 212 come alive. I'm sure it'll make a 224 hit like a wrecking ball down low.
Getting that hard pull outta the low side, will make you change gear ratio to calm it down.
Here's my son's ducar 212 with a 14cc head. It still has the governor working at 5400 rpm with the stock rod and piston.
It puts thrown together with GPS high dollar parts, slide carbed, ungoverned engines to shame.
