Sandmanbjj
- Messages
- 218
- Reaction score
- 257
I pulled off the gy6. And all the insane amounts of wiring. I wanted to see what kind of situation I would have to mount the 420.
Looking at the current frame, it looks like I will need to weld in a crossbar and mounting plate on the bottom of the swing arm. I have to measure the height but I'm sure I will have to cut and relocate the top cross bar for clearance.
But the glaring concern I have is the sprocket is on the passenger side. And it's only 32 teeth. I am assuming I will need a 60 tooth sprocket on the axel if I go with a 10t on the series 40 tc.
Can I flip the axel so the sprocket is going to be on the other side? Or is it just easier to buy a new axel with the sprocket on the driver side?
