What is the machine and rear tire size...
I'd gamble a guess that the air filter is why you lost e.t.. it's like putting a 3" intake on a Honda Civic, you'll gain flow up top while sacrificing your lower end torque, it all has to do with velocity!
The stock "intake" on GX series and clones actually have a intake runner that "straitens" the air (laminar airflow) and aids velocity whereas a filter right on the carb does not, it just allows it to breathe better in the in higher rpms where the stock "intake" becomes a restriction.
An air filter is not a tuning device
How does the convoluted plastic box function as an airflow straightener better than a cone filter that provides a straighter shot down the carb and runner?
Can’t have your cake and eat it too, but who wants to have a cake sitting around.
If going to modify, remove the governor.
If keeping the governor, don’t modify.
Did we at least back out the throttle stop and repeat the test at ~5k max rpm?
Here's my theory:
Honda doesn't just slap any old thing together and call it a day. They engineer, test, reengineer, and so on till they find the best ratio of power, reliability, and cost. If it was possible to reliably get 8-10HP from a ~200cc engine at under 3600 rpm (which is the industry standard for small engines), and have it be economical and user friendly, they would be doing so.
Any modifications that increase the power output will inevitably decrease the longevity of the engine. The only 2 reasons I could think of to keep the governor on are 1) because you're either trying to prolong the life of the engine, or 2) some sort of racing league that stipulates governors must be untouched.
If you're trying to prolong the life of the engine, leaving it stock is the only way to do so. Upping the compression ratio, advancing the timing, and running a longer duration cam are about the only ways to get significant gains under 3600 rpm, and those things will most certainly shorten the life of the engine more than over-revving it by 30%.
I personally believe all the stage stuff is a gimmick and meant to sell parts.
There is real performance to be had out of these engines, but it can’t be found by simply bolting on a kit.
Claims
Some people say you can take a 5-6.5 stock engine and then bolt on a stage 1 kit and you get 10-12 hp. I am not one of those people because I have tested stages 1-4 on my dyno.
Real Numbers
On a briggs flathead, you see about a 0.5 hp with a "stage 1" mod.
On ~200 cc small block OHV engines, you see approximately 1.0 hp gain with a stage 1 mod.
Big block sees more than 1 hp gain with stage 1 mod.
Governor
cheap china engines like predators have weak governor return springs, so you can overpower the governor to valve float.
genuine hondas with stage 1 cannot rev past 3600-3800 from what i have seen as long as you dont bypass the governor.
There is a measurable improvement (around .2-.5 hp across the same rpm band) when bypassing the governor vs governor intact with stage 1 mods.
Conclusion
Stage 1 mods give you a 1 hp gain and no speed increase.
You want to go faster? you go beyond stage 1 or re-gear.
HP claims that go beyond this are not accurate representations of reality (which you have done with your butt dyno). If, in fact, one was to double their hp simply by doing a stage 1 mod, then one would accelerate twice as fast. The reality is you get about a 15% gain, which is actually pretty good!!!
Keep in the game brother.
Claims
Real Numbers
Governor
Conclusion
The problem with the old Briggs flathead was that it was pretty much neutered from the factory. So anything a guy did to it was a massive improvement. Those engines came off the assembly line with only 5.5 to 1 compression ratios. That's why most of the things could run forever if they were taken care of. Honestly, that turned out to be a good thing. The problem was that they reached legendary fame because it was so easy to improve on their performance. The issue with that is the stock performance wasn't that great to start with.As much as I love a Briggs engine the fanboys totally ruin the nostalgia for me with the unending BS about these engines.
Well on my home made kart I have a 196 clone that will go 45mph gps app on my phone . Govener still connected. Put a vm22 carburetor with the air filter made my own exhaust pipe and flange out of 3/4" gas line welded it to a muffler that came off of a four wheeler. No kit or other mods to the engineSo, the Stage 1 kit is installed on my GX200. Everything is secure and it was installed properly....air filter, header exhaust, re-jet.
I would love your suggestions. On several tests with the Stage 1 kit, my acceleration and top speeds are virtually identical. The comparisons were all run on the same stretch of asphalt.
Do you have any ideas if something else needs to be done to gain any performance from this kit?
Really these stage 1 profamance kit are a gimmick. My kart is pulling 45mph on a stock 196 clone engine with a VM 22 carburator and a home made headder pipe and ATV muffler govener still connected.Stage 1 Kit NOT Better For Me
OK, instead of guessing and asking for "help", I spent today doing my own testing.
If you want to save time and know the end-results, the stock Honda GX200 performed a little better than the same engine with a Stage 1 Kit installed (bought from Go Power Sports). My advice: save your money!
I ran two tests with my go kart and its Honda GX200. The ONLY difference in setup between the two tests was the following. Everything else was 100% identical.
Different Test Setups on the Engine:
** On the first set of runs, I ran the engine with the Go Power Sports Stage 1 Kit
** On the second set of runs, I ran the engine 100% stock original.
First Tests With the Stage 1 Kit on Honda GX200:
** Several times, I measured the time to go from point A to point B; I started from a dead start, not a rolling start. RESULT was an average of 9.1 seconds.
** Several times, I measured top speed over a set distance from a dead start. Max speed was 26MPH.
Second Tests With Honda GX200 in stock/factory condition:
** Several times, I measured the time to go from point A to point B; I started from a dead start, not a rolling start. RESULT was an average of 8.3 seconds. Exact same distance as before. BETTER than with the Stage 1 Kit by almost a full second.
** Several times, I measured top speed over a set distance from a dead start. Max speed was 26MPH, exactly the same as with the Stage 1 Kit.
Based on my results, I believe the Stage 1 Kit is purely a gimmick with only one benefit - it looks cooler than the stock parts, and depending on your point of view, it might sound cooler. Other than that, you are out $75 and annoy the **** out of your neighbors.
