Stage 1 Kit NOT Better For Me
OK, instead of guessing and asking for "help", I spent today doing my own testing.
If you want to save time and know the end-results, the stock Honda GX200 performed a little better than the same engine with a Stage 1 Kit installed (bought from Go Power Sports). My advice: save your money!
I ran two tests with my go kart and its Honda GX200. The ONLY difference in setup between the two tests was the following. Everything else was 100% identical.
Different Test Setups on the Engine:
** On the first set of runs, I ran the engine with the Go Power Sports Stage 1 Kit
** On the second set of runs, I ran the engine 100% stock original.
First Tests With the Stage 1 Kit on Honda GX200:
** Several times, I measured the time to go from point A to point B; I started from a dead start, not a rolling start. RESULT was an average of 9.1 seconds.
** Several times, I measured top speed over a set distance from a dead start. Max speed was 26MPH.
Second Tests With Honda GX200 in stock/factory condition:
** Several times, I measured the time to go from point A to point B; I started from a dead start, not a rolling start. RESULT was an average of 8.3 seconds. Exact same distance as before. BETTER than with the Stage 1 Kit by almost a full second.
** Several times, I measured top speed over a set distance from a dead start. Max speed was 26MPH, exactly the same as with the Stage 1 Kit.
Based on my results, I believe the Stage 1 Kit is purely a gimmick with only one benefit - it looks cooler than the stock parts, and depending on your point of view, it might sound cooler. Other than that, you are out $75 and annoy the **** out of your neighbors.
