How to DOUBLE your China clone's Power
karl
North east Ohio
Should I throw $30 into this for a double row #40 chain coupler? Rest must be used/junked parts and scrap in the garage.
Two junkyard 208's = 416cc
That would be cool if you could get the pair to work together.....
Obviously getting the two in sync will be the greatest challenge, aswell as having the correct firing position of the opposite coil...
Im told its doable to make a custom ignition wire so you will have the length needed...
Youll need to come up with a custom air ducting and a more firm permanent joining mounting plan.
Id suggest a flex Lovejoy coupler for the two shafts, to minimize the interference of the shafts axial misalignment.
I wonder how DIY this could be done???
JTSpeedDemon
2019 Build Off Winner!
Texas
I want to see you do this!
And then hook it up to a converted Comet FNR gearbox to have 2 speeds! :auto:
karl
North east Ohio
Yes, of course they will work as a pair
The other coil, 180 degrees out, will be adjustable, and a jig that fits tight on the #1 coil will set base timing for coil #2 , and just extend the coil wire out.
As far as cooling, cooler burning fuel
The motors mounted on a stiff base, then a girdle on top the blocks, and a cage around the coupler, connecting side cover to the 4 charging coil studs , ect.
The more rigid the blocks are connected, the less misalignment there will be from vibration
I got this, no worries
ChargerMiles007 on youtube will give you an idea, but his vibrate like crazy, only connected at base of motors.
This will idle and be put under load.
Jt, that's getting out of budget! Haha would fit the theme
karl
North east Ohio
Alright, I think the L100 lovejoy should be sufficient, 22hp at 3450 rpm.
So the budget is spent!
karl
North east Ohio
Motors assembled,governors deleted, blocked off dipstick, shafts ground, no hemi's
I am missing a valve cover, springs, and I noticed a valve rusted up. So stock cyl heads it is
karl
North east Ohio
The coupler is massive! I cut one side down, one to go.
karl
North east Ohio
This thing will be a pain to pull start lol
Naahhh she'll be right
motors are stock, will run single gx390 carb :thumbsup:
I upped the budget $6 and bought a matching valve cover. Cant decide, polish the old one, or rust the new one :roflol:
karl
North east Ohio
Pink haha Ill compromise, since I already glued the covers on with SI 5900 instant gasket, ill grab a can of paint and cut off wheels for the base tonight.
The engine cover and base will be pink.
uhhhh now.. where to get a Barbie sticker these days? :eek:
PS I was just kidding.. but now I kinda like it.. +1 vote for "Fun" :D
karl
North east Ohio
Thanks , I got some decals on the way :p
karl
North east Ohio
:2guns:
