mindymogul
Mistress of Destruction
So in the increasingly crappy pile of crapshoot crap that's been slowly building it's crappy way to the crappy ceiling of my crappy shed I pulled out a not-so-crappy 'Cumsee from the engine sludge that's made it's way to the crappy unfinished floor. (Hot Rod Tech Tip: Old engine sludge works GREAT as a wood sealer). Problem is that this particular one was forged from nightmares and crappy Michigan QC standards, so the charging coil don't work (replacement is $50-$80 so blow me) and the throttle linkage is made for manual use only. The model is a OSHK130 13HP OHV in which I can't find ANY info online for mods or even just basic tech tips to this this thing throttle cable compatible. Anyone who's dealt with these engines I'll consider you a god. The least fabrication the better because the governor is already temperamental (1/16" rod adjustment threw it into full schitzo mode) and I really, really, REALLY don't want to go with the original idea and you the gov arm as the attach point for the cable (Even though it'd be the easiest)
