Tecumseh OHH60-71107C to Predator
Budget GoKart
Aka a kenbar
roachdale, indiana
I also add a spring to the arm of my builds that helps the arm return that might help. sorry if i sounded sarcastic but it just looked like you where not reading our replys, once again im sorry if i sounded mean.
950speed
Texas
I’m a third to add, I also have added return springs on all of my engines, it greatly helps.
gibbywmu
Thanks guys! It's fine, no worries. Maybe I should have read closer and inspected before I started posting. lol. I ordered a new throttle cable which will be here today, that was my issue. Previous cable was over 10+ years old and was kinked causing the "non" return to idle issue.
I'll take some more pics tonight. Last thing to do is put the torque converter back on (Although I did order a brand new predator kit........these old comet clutches are old and rusted, might be worth just doing new). Also got to add the kill switch to the steering wheel which was also broken.
Dingocat
Broke
NE Ohio
If anything switch out the pulleys between the kit and the kne on the kart, although I perfer the comets.
gibbywmu
Hi Guys,
Here's the update. Got the new TC kit in today, so I just used the Driver and Driven pulleys from the kit, as well as a bolts/washers/nuts from it. I didn't need the mounting plate, since the this old Manco 485 (Tecumseh) already had this clutch mount w/ jackshaft on it, so I just stuck with that. I probably could have tried to use, but I think it would be sitting to much lower on the frame, and I'd end up having to just cut the clutch mount off. Much more work.....although I do like the idea of the belt guard for kids. I don't see any way of putting one on here. The one in the kit mounts to the plate with 4 bolts. This way I have now seems ok test running on the jackstands. I don't see any issues. Pulleys look in line too.
Next step is I'm replacing the bearings in the front tires, then I'll be able to test drive it out.
*Note - Put the new throttle cable on last night. What a difference! Old cable was definitely bad. This one returns to idle with no issues.
Budget,
Didn't you say you wouldn't mind taking the old Comet Clutch parts I have? I'll give them to you as long as you pay the shipping.
gibbywmu
Forgot to ask...........what's the main difference for the different sprocket that was in the kit? The kit had a 9 tooth. My old sprocket that I reused was an 8 tooth. Is the smaller for more top end?
JTSpeedDemon
2019 Build Off Winner!
Texas
Yup.
And the bigger sprocket has more metal between the shaft and the teeth, meaning less chance of damage.
gibbywmu
Thanks Speed Demon. What do you guys think the top speed will be on this? Maybe 25mph tops with the current setup?
950speed
Texas
Yea somewhere around there I would assume, but it all depends on conditions. I’ve gotten my two seater manco to go 40 and that’s with a stock clone engine and gearing, but now it has a stage one and has more off the line power
gibbywmu
What do you guys think of the chain slack? I've read somewhere between 1/2-3/4 max flex.........that true? Think its about that now. Can't test drive it until tomorrow when I get the new bearings for the front wheels. Seems to be ok when I run it on the jackstands.
I loosened the engine bolts up and slid the engine back as far as it could go too.......
Thats a hard no...
Definatly need to be under way more tension...
Might need to jack up the engine with some washers...
3/8" to 1/2" of chain deflection...
Turn the wheel about while pinching the chain, youll see the amount to take out... probably about an inch...
gibbywmu
Staff Murderator
See video of the wife and myself. LOL
Hey, you figured it out (flipped your phone over) but your wife took some awful vertical video.
Only together, can we cure this epidemic. :D
:lolgoku: :oops: :funnypost:
gibbywmu
Yup :). That's why I edited it. If you watch the 1st few seconds, it's incorrect.........but just stick with it and I changed that. lol
