Anyone recognize this type of Axle?
WWC100502
Seems fairly heavy duty compared to a lot of the stuff I've seen online trying to figure out anything about this Kart. I'm assuming the double flanged piece should slide off the axle rod? Bearings underneath maybe?
...Sorry for the new thread, tried adding pictures to the last one and couldn't get it.
I don't even know who you are and it's not my job to look up your "last thread"...so maybe, uh, bring us up to speed?
What's this axle go to, what is it connected to?
Maybe our famed moderators can merge the threads. :thumbsup:
WWC100502
My apologies Hellion, I figured it out, a couple minutes too late. Additional pictures attached. Original post was just asking if anyone recognized the Kart.
No worries.
Looks like a buggy more than a traditional kart. The lines get blurred when things like that become more of an ATV thingamabob. Maybe Chinese (ugh). Someone will have an idea.
EDIT: you'll get better assistance if you roll that thing out of that cluttered garage and into some natural light and away from all that junk and stuff in the background.
Some forum members here aren't gonna give it a second glance because of your not-so-good pics. In other words, you're not doing yourself any favors. :( :eek:
Holmes
Oregon
I've only just started this addiction, but I'm already wondering what is the line between buggy and kart... is there a thread discussing this topic?
JTSpeedDemon
2019 Build Off Winner!
Texas
To me, the very limit of a go kart is Dingo/AmEx 2.0 style front sprung spindles.
Anything more than that suspension wise I classify as a buggy or mini buggy.
WWC100502
Does this look like it was intended to be keyed, but was welded instead to you guys? I'm replacing the chain and belt, possibly the brake disc, and was going to go ahead and disassemble/clean the rest up and check/replace the bearings as well, not that I've tried very hard at this point, but kind of stuck right here for now. Going to take the other side apart tonight and see if it looks the same. I'm assuming this is the rear axle hub and it's going to need to be removed to replace the brake disc, there's no give or slide in it at all with a gear puller so not sure how to proceed.
