jr dragster T
Lol, Your porting a wire brushing makes me cringe. If you want to build a real engine AND set everything to proper specs, Total dissasmbly is a must. BTW your not lapping the valves properly with the tappets still inplace. Old valves sink into the head and therefore have very little valve lash. To port properly you have to get in around the valve guide and 1/16" or closer to the bottom of the valve seat. Porting isnt a quick 10 minute half butt job. Do it right do it once and you will be impressed. Hope that helps. BTW most valve lapping compounds are oil based and you thin with oil
