MY1020 Motor and JX Controller
TIGL
yes, flipping the blue and yellow phases plus the green and yellow halls gave me perfect reverse. Of freaking course, not 9 hours after I get the hardware reverse wired up the eBay seller finally gets back to me.
oh well
TIGL
copiable Chinese chars since i cant upload the word doc and the PDF is too large. DM me and I can email it to you or I can throw it on a google drive
客户 上海司顺电子商务有限公司 Model 15 MOSFET 48V 1800W
文档编号 QYP15WF01-A SKU 1800WWSDJJKZQJTSBV0
配置 Voltage:48V,Off voltage:39V,cruise,speed limited,Low-level brake,
Current 30A
名称 图样 线位说明 CHK01-A
Power 7.8-2插片座 1:Black -
2:Red +
Motor Phase U:Yellow V:Green W:Blue
Hall 1:Red 2:NCC 3:Black
4:Yellow 5:Green 5:Blue
E-Lock 1:Orange VCC 2:Red P+
Display
1:Yellow 2:Red 5V 3:Black GND
2.8-9集成
1:NCC 2:NCC 3:purple12V
4:NCC 5:NCC 6:Green SL
7:Yellow 8:Black NGD 9:NCC
(Low-level brake:6:Green +8:Black)
converter 1:Black GND 2:purple 3:eek:range VCC
Throttle 1:Brown 4.3V 2:Black NGD 3:White SD
cruise 1:Blue Q 2:Black GND
Reverse 1:Brown DC 2:Black GND
Speed limited 1:Grey XS 2:Black GND
2 speed 1:Yellow K1 2:Black NGD 3:Blue K2 (don’t use it)
charge 1:Red P+ 2:Black GND
防盗电源
brian90vette
The supplier sent me the English translation a while back it should have been posted in previous posts. On the speed control it says this:
2 speed
1:Orange 2:Black NGD 3:Blue (don’t use it)
I think the "don't use it" part kept me away from messing around with it.
InteliWasp
TIGL, Is there a second brown wire or do i rewire the throttle to get reverse? I am confused.
TIGL
I have no idea. I looked briefly at our controller and didn't see the right wires so I'm sticking with my hardware reverse for now. I'm using a beefy 3PDT switch to flip the phases and send a signal to a DPDT relay that switches the halls
crjessee
Thank you for the reverse!
:cheers2:
We cracked it!!! Flip the yellow and blue phases and the yellow and green halls and you’re Gucci
I finally have reverse which is my forward in this case, I am disgusted by the process of no wiring diagram or info at all, but you boys keep saving the day, thanks to FA and Sid as well, they are doing great work, thanks all.
I agree the yellow and blue phases and the yellow and green halls are switched and the opposite direction of rotation is the result!! High gear appears to work or the two speed so that is sweetness but also the low speed is going to save lives so it's cool feature. This is working well on the bench now to get some wind in my hair, switching out the sprockets now but had to come thank you guys first! cheers!
Thanks for the education! What a day!
---------- Post added at 11:58 PM ---------- Previous post was at 11:48 PM ----------
JX Brushless DC Motor Controller
48V 1,800W 30A
JX - CSJD15WF01-A
The first flight has taken place! Wow! Pretty cool motor, I love the brushless compared to my brushed motors as it is very quiet and it hits hard in high gear so I can wheelie at will but I agree it's not really what the specs say but it's got some top end legs now and it's way too fast to let anyone else use top gear. Installed in a Monster Moto MM1000 Electric mini bike chassis and upgraded to lithium battery for this 48volt motor, I guess it's a MM1800Li now eh. thanks again!
TIGL
:cheers2:
48V 1,800W 30A
JX - CSJD15WF01-A
Can you explain how the speed settings work? Nothing jumped is medium, one side jumped to ground is low speed, the other side jumped to ground is high speed?
brian90vette
I tried messing with the different speeds and blue and black was mid speed and yellow and black was slow. Open was the fastest, which I already had, so no speed change for me. That motor is powerful no doubt
brian90vette
Let me know if your speed settings are different. I tried jumping yellow to ground and blue to ground both were slower than just the default.
TIGL
Will do. I have an optical tach I'll get actual number with tonight
bwana9114
Finally got our mini quad back together.
Converted from:
- 36v to 48v
- 500w brushed to 1800w brushless
- geared transmission to jackshaft
Pulls up the hills much better now!
-Steve
Gn4life
Did you guys ever figure this out?
Open with nothing jumped seems to be the fastest for me too.
When I do blue to black or any other combination it slows it down.
I still can't help but feel its not high speed on default. Just seems to quite and visually disappointing while bench testing.
The Ebay listing I ordered it from says this
"Speed Cables: Orange (High Speed) + Black (GND) + Blue (Low Speed)"
But that doesn't make sense to me because the 3 speed connector is blue black and yellow. There is No orange on the 3 speed part of the harness.
Sean1970
Fort Collins, CO
Hiya- I’m a new user here and am building a bike using two of these motors and controllers. And I have a couple of questions that I am getting nothing from web searches.
The first- and most important. Will two motors, each with their own controller, be enough to move something in the neighborhood of 700 lbs?
And it kind of looks like I can wire steps in the speed the motors will go? I am building it for an event and will want to ride it across town a little faster than a crawl but when we get to the event, I will need to move a little slower than a walking pace. Do the motors work ok at part throttle? Or should I gear it to run wide open at the speed I want?
Also, can I use the signal for one throttle to run both controllers? If that won’t work, I am planning on disassembling one so that I can stack them on the same shaft, but would rather not do that as I have it in my head that one throttle for both motors will balance them some.
Thanks
Thanks
Hello,
Wow! 700 lbs. is a lot
Yes they may be able to do it
...but, it's probably going to have to be geared really low (= "slow")
(so the motors don't overheat (work too hard)
You, shouldn't need to "wire steps" or what ever
IIRC...the controllers for these motors have a connection/plug to attach a "speed switch" (for low, med & high gear/speed)
I haven't tried it but, I have heard of others that have used (1) throttle to send a signal/control to (2) controllers "simultaneously"
Gn4life
Hello,
Yes there should be a 3 wire plug usually marked "speed" or something similar. It looks very similar to the throttle plug.
You can hook it up to a 3 position switch to obtain low speed Medium speed and high speed . Ans switch it on rhe fly.
The only tricky part is figuring out which wire combinations cause wich speed. Also because it seems some controllers come set as high speed as the defualt while others come set as Medium as the default.
brian90vette
Yeah visually disappointing is a good description on the bench test. However when I actually got the motor installed the Torque was impressive and it wasn't represented on the bench. The top speed was a little disappointing, that's why I had hope when I read about the 3 speeds but was dismayed to discover the way mine was, like yours, was top speed open pins.
Gn4life
Thanks. Exactly my experience too. Good thing I recieved a $15 refund because the motor case was scratched up and it came with a 9 tooth sprocket instead if the 11 as advertised.
So i was only $16 out of pocket for the whole kit. Even though im disappointed with the speed its well worth the price.
