Here are the instructions....
http://www.minichopperssocal.com/MINIBIKE-PL-1.html
They changed the design on the steering head tube. Said bearings weren't needed and they had issues with the bearings in the past.
The seats are made in China and the specs change. So he said to just drill out the holes on the frame to a bigger size. I guess that is the easiest solution. Not thrilled about it.
The rear axle spacers... he said I shouldn't need washers. He said the frame is relaxed and will tighten up when the nuts are tightened on the axle. He said it should only be 1/16", but I'm guessing it is closer to 1/2". I'm going to get some washers.
As far as the bolt for the internal drum brake.. He said cut off 1/4" of it.
Then I'll start looking at mounting the brake caliper.
Since bringing the bike back to the workshop where the tools and engine are makes too much sense, I'm going to bring the engine and the tools to the third floor apartment.
---------- Post added at 11:33 AM ---------- Previous post was at 11:33 AM ----------
Thrust washers, sometimes called rotary thrust washers, are washers designed to prevent movement along the axis of a shaft.
So just like a regular washer, but it spins better? Is it needed for when using for axle spacers or can one use a regular washer. Does it matter if it is next to the bearing?
