- Messages
- 9,060
- Reaction score
- 4,054
Greetings all.
Some time back, I finally initiated an interest in minibikes and "joined the club" ('bout time!). I bought a $75 Rupp Continental that needs work but that tiny spark set things in motion.
I finally bought a Baja Warrior/MB200 just so I could be like Joe. In reality it is a parts bike, a clunker and it leaves a lot to be desired. Somewhere down the line it was stripped of its fenders, headlight, original engine, jack shaft assembly and left with a non working 5HP Briggs tiller engine. It's labeled as a 4HP if you look closely on the shroud but the engine code numbers denote it as a 13 cubic inch engine (therefore a 5 horse). Interesting little factory blooper there...or was it "detuned" for Sears/Craftsman purposes?
The seller was attempting to make it run before I bought it and if he was successful, he was gonna charge me more--I forget if he ever set a dollar amount or not. I figured it was a valve leak or out of spec valve/tappet clearance after I looked at it, because it had no compression, no resistance when pulling the starter cord.
Here's pics from the original ad:
Can you dig the paint tray chain-guard?
