Briggs and Stratton
courts94s
Noob
Fort Sill, Ok
Could you even screw in a muffler if you wanted to?
Yes
courts94s
Noob
Fort Sill, Ok
I got the 5hp Briggs broke down and cleaned up. I can't get inside to find too well. Here is a before of how back it was. There was grease and oil cooked on for 25 yrs.
---------- Post added at 05:15 PM ---------- Previous post was at 05:10 PM ----------
I removed the governor, but there was a brass shim in it. I removed it, but a 3/8 tap wouldn't dig all the way into the hole. The bolt goes in a little lose. I added a rubber washer on the inside then loaded up some thread lock. Hopefully it holds. Otherwise I'll have to use a 1/2 inch tap, I'm just worried about the thickness of the side wall where it protrudes out for the old governor arm.
---------- Post added at 05:22 PM ---------- Previous post was at 05:15 PM ----------
courts94s
Noob
Fort Sill, Ok
The engine is shiny and new looking..... but, it runs like crap! It surges real bad and shuts off after a 20-30 seconds of idling. I can't get the carb adjusted to idle correctly. I think I'll just store in, until I make an intake manifold and put a Predator carb on it.
KartFab
yeah it uses standard pipe threads
---------- Post added at 10:38 AM ---------- Previous post was at 10:36 AM ----------
the mikuni and walboro carbs are a good alternative too. They have prefabbed intake adapters for them. The $15 carb and custom intake i did was kind of a one off and needs some special consideration for throttle linkage. The mikunis/walboros dont have that issue with throttle linkage.
courts94s
Noob
Fort Sill, Ok
I was thinking about the Mikuni because of the easy throttle linkage. I really wanted to get this thing going with the original carb because it looks cool.
Kentucky Boy
Bowling Green, KY
I made my own. Flanges from flat stock steel and a steel pipe cut and bent and rewelded. The intake gets very cold when it's running. Pretty cool.
