How do I make a Go Kart (WITHOUT a Welder)
Gan
Your Boy
Southern California
Just have a garden hose on standby or a few fore extinguishers...unless your in the People's Republic of California, which is a fire hazard of a state then you should be fine.
In fact, yes, yes I do live in California. Southern California, if you would like to get specific. There have been several wild fires around me (almost 5 or 6 in just the past year) and they have traced several small fires (not the major ones but still a wildfire) back to a BBQ mishap, cigarette disposal, and more. It is extremely dry because we are in a drought situation. All around my house are dried out plants and I have no doubt in my mind that they would catch fire in an instant.
I know I could have the fire station on speed dial, however I am not comfortable at all with using a welder because I have never touched one and I do not have a proper place to use one either.
Now I get it, you previously burned down California trying to weld and are now looking for an alternative option while preventing self incrimination. ;)
Jfive
Great falls Montana
Its funny cause welding was first used to replace bolts or rivets and now you are trying to revert back.
I think a bolted frame can be good as welded, but it will take a lot more money.
Drill bits and bolts aren't cheap. I'd get some rapid tap for drilling.
Harbor freight bits work pretty good on a budget if you use cutting fluid and keep the bits oiled.
Tig welding is really safe as far a starting fires or sparks.
I weld in my driveway with stick/arc, in the garage with tig. I'd use square tube and angle iron for joining in corners.
Need two bolt minimum to keep it rigid on each side so four bolts per corner.
Could use Rod ends for spindle supports. Honestly I'd do some welding just cause drilling would get old.
Iron John
NA
OP, there are people on this board who are super helpful and some get all hung up on location. "What gear ratio should I use with 10" tall tires?" "Where do you live?"
Obviously the answer does not depend on that, they are just being friendly I guess.
As to that diagram you drew, if you used tall angle iron for the frame rails and less tall angle for the front (one) and rear (two) crossmembers (one on each side of the motor plate) there is no reason you cannot bolt it together. You would not even need as much triangulation as you included. It's a go kart, not a semi trailer, and go karts were even built of wood in the 40s and 50s.
In fact, if you are a good woodworker, the strength-to-weight ratio of wood is better than steel. The floor could be a stressed member, construction-adhesived to the frame rails. It is absolutely doable without hurting busloads of nuns and children.
Prove it motormouth. Link the post where ANYONE asked for a profile location to answer a gear ratio question. Just because you're a location paronoidal don't make crap up.
I'm a master carpenter and woodworker for over 30 years...you couldn't make a pimple on my rear....and I DON'T recommend a wooden kart unless the builder has at least stairbuilding experience...and better yet boat building.
---------- Post added at 04:05 PM ---------- Previous post was at 03:54 PM ----------
Then you shouldn't build a wooden kart.:rolleyes:
pRoFiT
Can't buy it?, build it!
California
I think poboy has memory issues. Google is not hard to do.
found one. http://www.diygokarts.com/vb/showthread.php?t=29583
two http://www.diygokarts.com/vb/showthread.php?t=30676
three um hmm, this one you did give help and ask for location :) http://www.diygokarts.com/vb/showthread.php?p=369083
um here is one about belt sizes. http://www.diygokarts.com/vb/showthread.php?t=33481
Not like location is a new issue on this forum.
http://www.diygokarts.com/vb/showthread.php?t=31025
http://www.diygokarts.com/vb/showthread.php?t=31026
http://www.diygokarts.com/vb/showthread.php?t=32623
Maybe there is a way to have the newbie signup part force people to put in a location? problem solved right? :thumbsup:
Steel Soldiers forces new members to put location down while signing up...its a bad policy. Sure its helpful in some regard but some do value online anonymity, to be on the safe side.
Sent from Tapatalk while on the porcelain thrown!
Oh man!!! California!:mad2:
That explains it. Just move to Tex... Er wait...
Nevermind Carry on!
No...you have cognitive issues....apparently, you can't read.
Not one of those links says we NEED a profile location to answer your question. In the first 3, I merely asked PLEASE fill out a profile location. You got a problem with that? (And they all did...) For pete's sake...the first guy was in Australia!
Secondly, making it mandatory wouldn't help...because they would just lie like you did on yours...(you seriously aren't on the same planet as the rest of us)...Or fill out a BS location like IronJohn.
Btw: One of those clearly says:"Where can I get this part?" Funny how it's always the jerks that don't fill out a profile location that want to make a big deal out of it....There's like 3 of y'all that aren't newbies that are paranoid misled individuals thinking not filling out a general profile location provides some kind of internet security....:roflol::roflol::roflol:
Iron John
NA
You, sir, have no cause to be calling me out and insulting me on a public forum.
Furthermore - I do not believe that you own this forum. There are other places here for individuals to suggest their ideas. Threads like this are not the place.
pRoFiT
California
Sorry i didn't see this was a regular thread. Just one more comment. I don't see how my location helps anyone. If i need help buying something, it needs to be an online store (nothing local for me). And is it legal where i'm at? probably not, but i don't care. So it does not matter.
Okay sorry Gan continue your fire hazard go kart. I'm near handford and man did they have a big fire. Hard to breath out here last week.
See now that you know that, ya'll have something in common to talk about. It just helps the forum be more fun.
Are you so delusional as to deny that's a BS location?
Who called who out first? I'm just defending my position....you are the one overstepping boundaries....I stated a fact...you made an accusation .
When did I ever say I thought I owned this forum? However....your BS profile location is there for the whole world to see.
I shouldn't even have posted this...you're not worth the time.
Gan
Your Boy
Southern California
Thank you for the advice. Will be sure to take notes on the number of bolts needed so that the frame will not flex.
---------- Post added at 07:43 PM ---------- Previous post was at 07:41 PM ----------
Thank you for the advice! I sadly, am not a master woodworker, however, I have created some pretty cool wooden playgrounds for my two parrots :wai: Other than that, I haven't done too much woodworking besides little things here and there.
---------- Post added at 07:46 PM ---------- Previous post was at 07:43 PM ----------
Nevermind Carry on!
LOL. Texas= Poboy kartman hazard.
---------- Post added at 07:49 PM ---------- Previous post was at 07:46 PM ----------
Ironic that poboy thanked you for this comment, considering he started a comment section wildfire on location. (See what I did there)
---------- Post added at 07:51 PM ---------- Previous post was at 07:49 PM ----------
Okay dude, you're seriously salty. No one is attacking you, yet you're attacking everyone. I would seriously hope that a senior member wouldn't be this rude.
