Should i cut my losses and resell?
Kaptain Krunch
Pro Junk Collector
vermont
Well i bought an 83 RM 125D for $170, the seller assured me it ran, and lost its spark but will run fine again if i could get it to spark. Anyways i Bought a new CDI after some troubleshooting for $65, fixed my no spark problem. The engine had good compression so i tried starting her up, kicked it over quite a few times and figured the carb was gummed up so cleaned that out, kicked it over quite a few more times still nothing, i put a little pre-mix in the cyl and it kicked over, so i kept kicking it. All of a sudden it just seized, so i took off the side covers and got it unstuck with a socked, but it was still hard to turn over. Anyways i tore apart the engine and the connecting rod has a huge crack in it, and i found some metal shards in there. The cylinder and piston are fine, i havent checked the crank yet (dont have a flywheel puller for this engine). Anyways est. cost of a rebuild would be around 150-200, i already have 235 into this bike, is it worth it to rebuild? or should i cut my losses and try to resell the bike? The frame is in good shape, plastics are cracked up on one side and painted black.
Kaptain Krunch
Pro Junk Collector
vermont
I wanted the bike, i was hoping for a cheap beater...but its turning out to be not so cheap, but i guess $400 isn't all that bad for a good runner.
Kaptain Krunch
Pro Junk Collector
vermont
No it was a brand new plug and had a great spark. Either way it not running was a good thing, because if it started up and i rode it away chances are the rod would have let go and the whole thing would be ****ed right now.
thgrahamjr
Love To Build!
Clewiston Florida
Fixing it yourself is what it's all about, that's what we do. It may cost more to fix something than to buy a new one, but where is the fun and satisfaction of making something work that didn't if you buy new?
Kenny_McCormic
Kartless....
Michigan Troll
Doing big end rod hearings isn't that hard. If you have a press, V blocks, a dial indicator, and a couple of brass or lead hammers you are good to go. Press it together eyeballed and beat on it till you get 0 runout.
Kaptain Krunch
Pro Junk Collector
vermont
I dont have v blocks or a dial indicator, or brass/lead hammers but i can most likely barrow most of the stuff i need.
Kaptain Krunch
Pro Junk Collector
vermont
Anyone have tips for splitting the cases? i dont have the special tool, and dont really want to buy one...
Kaptain Krunch
Pro Junk Collector
vermont
Well you guys did convince me for a while, but its just not worth it, ill lose more money than ill make resseling. I put it on craigslist for 225 already got someone whos interesting, ill be losing $10 which aint too bad.
On a side note, who here has seen nitro circus? i was just watching and its sad, they were beating the hell out of a brand new rm250...riding it over concrete barriers, Revvin the **** out of it...I mean if there gonna do that, they can have my bike and i'll take that new one off their hands..
spilde24
nitro circus has got to be my fav show and i shed a few tears seeing those bikes abused, i guess thats just the way it is...
