To make a leak down tester or to not make a leak down tester?
Test 125 psi from the chamber side. Test the valves and the rings.
LOL
That is the question.
---------- Post added at 02:11 PM ---------- Previous post was at 02:04 PM ----------
How to convert HF Compression Tester into primative leak down tester.
https://www.youtube.com/watch?v=fmavwDldl8M
---------- Post added at 02:15 PM ---------- Previous post was at 02:11 PM ----------
Does this make any sense? Or am I still way off. Do I get to keep my man card?
I feel the leak down tester is the GAB way to go.
---------- Post added at 02:36 PM ---------- Previous post was at 02:15 PM ----------
At least with the 10.8 lb springs, The installed spring height is right around 0.850" with the stock valve and retainer.
The installed spring height with the SS valve and its retainer is ~0.800".
I tried to account for the difference in retainer thickness when measuring, but I don't think the 0.050" will cause a huge difference in seating pressure, nor do I think a small difference in seating pressure on each of the valves will do any harm?
The 26lb springs are the same length as the 10.8 lb springs.
---------- Post added at 03:08 PM ---------- Previous post was at 02:36 PM ----------
I feel like this is the appropriate style of music for lapping valves. OR KILLING VAMPIRES.
https://www.youtube.com/watch?v=pZs8VQ6LxsY&index=10&list=PLLm9h4_cqlM6LSePofHrngtzLhlxi6o_a
Jrgunn5150
Rudderless
LOL
[/COLOR]Does this make any sense? Or am I still way off. Do I get to keep my man card?
It's a good idea, and a helpful diagnostic tool to have. Much better than a WAG.
So I lapped.
I put oil on the stem.
I put valve grinding compound on the seating surface.
I used the suction cup valve lapping tool.
I used 1/2 rotations. Back and forth (maybe 5 times each) as my hands slid down the lapping tool.
Then I would pick up the lapping tool (valve still attached), rotate it 1/4 turn and plop it back down.
Again, 1/2 rotations, back and forth.
I did this until the sound barely changed from when I plopped it down and after some rotations.
I would call this ONE lapping. It took about 5 minutes.
I did this THREE times.
The last one, I spent extra time. I'm sure the compound gets finer the longer you work it. I maybe spent an extra 3 minutes after I thought it sounded done.
---------- Post added at 04:19 PM ---------- Previous post was at 04:14 PM ----------
To appease the gentlemen of the court, I will attempt the same test with the 10.8 lb spring again.
---------- Post added at 04:27 PM ---------- Previous post was at 04:19 PM ----------
So I figured out the trick with these split keepers.
I have to get them in, one at a time. When putting the second one in, I position my thumb in a way where I can use the back of my thumb nail to guide it into position while i compress the spring. All while using my knee to support the face of the valve.
Not sure it will be that easy with the 26lb springs.
I video the test.
---------- Post added at 04:40 PM ---------- Previous post was at 04:27 PM ----------
OK the uncompressed 10.8lb spring is 1.165"
The spring relief factory cut into the head is 0.050".
Face thickness on top of Stock Retainer is 0.060".
Face thickness on top of SS Retainer is 0.100"
Installed height of 10.8 lb spring with SS valve/retainer is ~0.77"
Installed height of 10.8 lb spring with stock valve retainer is 0.86"
A little bit more of a difference than I thought.
Could shim them equal, but I don't think it should be an issue???
---------- Post added at 04:44 PM ---------- Previous post was at 04:40 PM ----------
IF THIS SHOWS NOTHING ELSE...
It shows that if I can get a seal with the stock valve and 10.8 lb spring compressed to 0.86" against my air compressor, I should be able to get a good seal with the SS valve and 10.8lb spring compressed to 0.77" against the same compressor.
---------- Post added at 05:21 PM ---------- Previous post was at 04:44 PM ----------
No Sound, but no Bubbles Either. 90psi
https://www.youtube.com/watch?v=P6KyX1s6_UI&feature=youtu.be
cavfire
auburn, georgia
OK, thanks. Back to the lapping.
BUT I know that a 26 lb spring, installed at a height of more that 0.85", takes less than 26 lbs of pressure to unseat it?
How does 100 psi, on say a 1" diameter valve, not cause it to unseat?
Maybe the intake change on forced induction engine might see back pressure build up like that? (PAFR 85 psi boost)
On naturally aspired engines, I think the intake valve would be open before back pressure got that high?
And I really don't know what kind of back pressure I would see on the open exhaust header.
Maybe I'm not following, but how would 100 psi in the combustion chamber cause the valve(s) to unseat. A 1" pneumatic cylinder at 100 psi will generate 78.5 pounds of force. Applying the same pressure to relatively the same surface area should give around the same pounds of force trying to keep the valve closed. I know the valves aren't sunk into the seat, but even if there was some kind of force applied around the head of the valve where it is angled the surface area is fractional compared to the area trying to keep the valve closed.
100 psi from the other side is what I was referring to. Coming out of the nozzle of the compressor. Blowing on the backside of the valve. Cracking it open. I realize the valve won't see 100 psi from the back side, but thought maybe enough to crack it open slightly.
It is sealed enough for me. I am ready to move on, but willing to keep this discussion going if anybody wants.
Spark plug indexing.
No...you have to look at it this way...the fuel charge you are trying to ignite is coming from the intake valve.....now...a plug with the electrode facing AWAY from it is blocking that charge from reaching the area the spark is happening...(it has to GO AROUND it!!!!)
Soooo...whether it's one cylinder or 16...there IS a benefit and it's consistent whether 1 hp or 1000... more consistent "light off" = more power....
And yes...now you can see how the worst position can hurt....therefore how the best will be with that gap pointed straight at the center of that intake valve.....and anything inbetween will have varying degrees of improvement.
From AGK:
This is an old trick that hot rodders have been doing for years. Indexing the spark plug will help clear the combustion chamber of unwanted gases. The goal is to have the open end of the electrode facing the exhaust valve after the spark plug has been tightened. Each indexing washer will change the position of the electrode by 1/4 turn enabling you to achieve the desired position of the electrode when the spark plug is installed. This upgrade may not provide the same "seat of the pants" increase in power as the above recommendations, but every little bit counts.
While Im commenting not to be controversial, but provide some enlightenment to both parties in this matter...... from the pros...
FROM NGK link: Thanks KUTZ
This is for racers only!!
Indexing refers to a process whereby auxiliary washers of varying thickness are placed under the spark plug's shoulder so that when the spark plug is tightened, the gap will point in the desired direction.
However, without running an engine on a dyno, it is impossible to gauge which type of indexing works best in your engine. While most engines like the spark plug's gap open to the intake valve, there are still other combinations that make more power with the gap pointed toward the exhaust valve.
In any case, engines with indexed spark plugs will typically make only a few more horsepower, typically less than 1% of total engine output. For a 500hp engine, you'd be lucky to get 5hp. While there are exceptions, the bottom line is that without a dyno, gauging success will be difficult.
---------- Post added at 09:10 AM ---------- Previous post was at 09:09 AM ----------
I only wish Brett was here to confirm!!!
A few hrs before work. Only a shift and a half now.
Some time to clean.
I got one reply telling me 0.050" Piston to Head.
EVERY other place, Including Jody at ARC say, 0.030" Piston to Head Clearance (but he sells parts right? The more they brake, **** break, the more they sell. lol)
IT HAS BEEN DECIDED! 11.11 :1!
Here are some of the specs...
0.027" Gasket
0.004" Deck Height
0.031" Piston to Head Clearance.
0.072" Intake Valve to Piston Clearance (zero lash)
0.081" Exhaust Valve to Piston Clearance (zero lash)
2.756" Bore
2.165" Stroke
18cc Combustion Chamber
3.328" Connecting Rod
27mm Intake Valve
25mm Exhaust Valve
26# Valve Springs
0.003" Valve Lash (Both Intake and Exhaust)
0.275" Cam Lift
230 degree Cam Duration
104 degree Cam Lobe Center
Intake Opens (0.050") 11 deg BTDC
Intake Closes (0.050") 39 deg ABDC
Exhaust Opens (0.050") 39 deg BBDC
Exhaust Closes (0.050") 11 deg ATDC
32 deg BTDC ignition Timing
0.030" Coil Gap
2.75" x 0.9" AVG DIAM Intake Port
2.75" x 0.9" AVG DIAM Exhaust Port
It now only takes me 5 minutes to get a SS valve in with 26# spring and retainer with split keepers.
This is an improvement over my previous 2 hour per valve average.
First one goes on easy with thumbs.
For the second one.
13 mm box wrench... Press and wiggle!
