That should be sufficient I think. I'm sure I left some parts out but you should be able to figure it out from the pictures. I think there was some caveman like bending of the plate at one point.
LOL good luck!
---------- Post added at 02:23 PM ---------- Previous post was at 02:11 PM ----------
Just like HF QC, Consistency is only sometimes important
3-11-16
bob58o -
"Anybody have experience with increasing compression on these 212 Hemi engines? It is all brand new to me.
I don't want to do any Milling."
4-25-16
bob58o-
"not sure CCs of original head, but would like it milled"
---------- Post added at 02:39 PM ---------- Previous post was at 02:23 PM ----------
SO WHEN I DO CHECK PISTON TO VALVE CLEARANCE WITH CLAY, WHAT IS THE SPEC?
USING BILLET ALUMINUM CONNECTING ROD? HOPEFULLY 6000 RPM
THANKS, I CAN STOP YELLING OVER THE VOICES IN MY HEAD NOW!!!
Bob
machinist@large
West Michigan, 49331
[/COLOR].....SO WHEN I DO CHECK PISTON TO VALVE CLEARANCE WITH CLAY, WHAT IS THE SPEC?
Bob
:eek: :eek: :eek: :eek: :eek: NOOOOO BOB!!!!! YOU'RE CHANNELING HIM AGAIN!!!!!!! NOT DOUG, THAT OTHER GUY!!!!!!!! NOOOOOOOOO!!!!!!!!! :smiley_omg::smiley_omg: :smiley_omg:
A safe figure is fifty thousands....when things break in, and centrifugal force and thermal length change kick in, clearance in actual operating conditions will be closer!
When you can't weld, you make do... Or doo doo. Rubber Grommet on Rubber Grommet on original Pedal stop. I realize I could move the throttle cable lower on the pedal (where the pedal is attached) but I like when things fail!
This is "Chicaghetto" Rigged. Lol
Edit: For Testing Purposes. I will move the cable lower.
Test #2 Coming up!
I put some more psi in the tires.
Testing how it idles, how it takes off, how it returns to idle, how the TC engagement is working, how it climbs the mountain (lol).
I'll Have GPS and tach, no action camera or bike speedo.
Stock TC springs/settings.
16" wheels
7.5:1
Initial check of plug was looking rich but I'll check after this test. Hopefully I remember to kill it at WOT.
I wished that other guy that lives in my head spoke English. I think its Portuguese and my broken Spanish only gets us so far. lol
---------- Post added at 04:46 PM ---------- Previous post was at 04:41 PM ----------
I enriched the idle mix a bit to see if I could get rid of the popping.
Now it stumbles when accelerating from idle. It seems like it will die if I don't ease into it.
Spark plug looked good. Not too light, not too dark.
A few more tests and I might have it as close as stock jetting will allow.
Then I'll see what gravity can do.
Looking into adjusting float and needle height. Not sure what this carb has adjustments for just yet.
Forget the float adjustment..."nothing to see here folks....move along...."
Basically, the only thing that can go wrong there is serious flooding! Seeing as a carb can run a couple of minutes on the fuel in the bowl....any problems there don't change quickly....It's in the jetting.
I would not go little or no lash on the valves. Metal gets longer as it expands and will close up the lash as it gets hotter. :thumbsup:
Yep...that would be my thinking, too....and conventional thinking would say that would happen. I think it's why exhaust valves usually have more lash than intake....However, now both valves are set at a very tight .003"????
Soooo.....I'm not exactly sure WHAT is going on....but it appears lash actually grows instead of closes!!!! Maybe because the cylinder bore is so much longer and massive....that it expands more than the short , quick cooling valve stems????? IDK?????
Just something I found.
http://www.wallaceracing.com/valvelash.htm
Compensating for a Cold Engine when Adjusting Valve Lash For Solid Lifters
When installing a new cam, the engine will be cold but the lash specifications are for a hot engine.
What are you to do? There is a correction factor that can be used to get close.
We mentioned that the alloy of the engine parts can be affected by thermal expansion in different ways,
therefore the amount of correction factor to the lash setting depends on whether the cylinder heads and
block are made out of cast iron or aluminum.
You can take the "hot" setting given to you in the catalog or cam specification card and
alter it by the following amount to get a "cold" lash setting.
With iron block and iron heads, add .002"
With iron block and aluminum heads, subtract .006".
With both aluminum block and heads, subtract .012".
Remember this correction adjustment is approximate and is only meant to get you close for the initial start up of the engine.
After the engine is warmed up to its proper operating temperature range,
you must go back and reset all the valves to the proper "hot" valve lash settings.
cavfire
auburn, georgia
Only thing I'll add to this is the adapter he's using puts the carb at a 15° tilt. Maybe something or maybe nothing, but I do think the volume of fuel in the bowl is diminished. I put a GX270 carb on a couple weeks ago and ran into problems with fuel level. Would start lean popping and shutting off when I let off the gas after a long high rpm straight. Was quick enough to close the fuel shutoff when it happened one time, and dropped the bowl to find it didn't have much fuel in it. My guess is with the butterfly open it was helping pull fuel into the bowl, but with it closed it lost the vacuum assist. No trash found in carb or in tank filter either. Yesterday was the maiden voyage after putting a fuel pump on it, and it ran perfect. Bob is already running a fuel pump so that shouldn't be an issue.
A pop here and there when letting off the gas of a modified carbureted motor isn't uncommon though. Especially with what is close to no load revving on jackstands. My thinking is the motor goes rich for second after the butterfly is snapped shut, and fuel is burned in the exhaust. Then again it could be the other way around. As long as there isn't drivability problems I'd hazard a guess that it's OK.
Bob58o I wouldn't look into adjusting the float as much as I'd look into the flat mount kit from NR racing if you think fuel level is an issue. http://www.nrracing.com/product-p/nr-cc390c.htm
Apparently, no one saw it "wide open " it looked really slow to me...(and I'm not just talking take-off....but drive-by....)
Yeah it'll be fun to watch them burn up TC belts instead of CC'S....:rolleyes:
UMMMM....Yeah reverse would be nice, but not building a stretch limo offroader would help!
At least it doesn't look like it'll break, and it has a seat and a foot throttle...and it looks like both front wheels turn together....sooooo....
Which makes me think hmmmm.....FreeRunner wants to do two engines too. Can't wait for the video of him steering with his feet! LOL!
Testing and thinking, thinking and testing...
On jack-stands, it performs fine. On the ground with me in it, it does not.
TESTING STARTING AT FUEL SCREW 2 TURNS OUT AND GOING TO 3 TURNS OUT...
When I give it gas, it seems like it will die. It will pick back up when I take my foot off the pedal. I haven't held it long enough to see it will die for sure. This happens at 2, 2.5, and 3 turns out on the fuel screw. On stands, somewhere between 2.0-2.25 turns seems to give me the best idle and throttle response.
I can give it gas slowly and get going, but even opening the butterfly 1/2 way won't work.
With the choke on, it will move when I hit the throttle (an improvement, but not very smooth)
Like you guys mentioned, it seems like either an idle jet or carb angle issue.
I'm guessing here.
A.) Better on stands because less load needs less fuel? Current jetting gives enough fuel to raise the RPM of the engine with no load, but under load the pilot circuit struggles???
Increase/clean Pilot Jet?
B.) Better off the line with choke on because the current carb/jetting/cam/air filter/exhaust allows too much air, not enough fuel? Pilot Circuit struggles to provide enough gas to keep up with high air flow?
Increase/Clean pilot jet?
Try with Muffler on?
C) Better on stands because the angle of the carb is different compared to the ground?
The engine sits on swing arm that is already angled. This seems to compound with the angle of carb adapter. It is less significant with an occupant in the kart. Not exactly sure if or how this relates to my problem
Not sure how to test this, I might just try gravity feeding the carb and see what happens.
D.) Possible leak on intake side? Extra air causing lean mix?
Spray WD-40 somewhere around the carb adapter? when idling and see if RPMs increase??
It seems like a lean pilot circuit, which kinda makes sense to me. I guess I have a plan.
1.) Open valve cover and see what lash is at before next cold start
Open again after testing and see what lash is after, when hot.
Adjust if necessary.
2.) Spray WD-40 by carb/intake and see if RPM increases.
Re-gasket and seal intake side if leak if found.
3.) Try similar fuel adjustment trials starting at 2 turns out and go in this time.
3.) Put muffler on and try again.
If better with muffler, it means the pilot jet is too small.
Seems like a reasonable plan of attack.
---------- Post added at 02:40 PM ---------- Previous post was at 02:33 PM ----------
Also Hissing/slurping sound near carb/intake right after I killed the engine.
