Testing and thinking, thinking and testing...
On jack-stands, it performs fine. On the ground with me in it, it does not.
TESTING STARTING AT FUEL SCREW 2 TURNS OUT AND GOING TO 3 TURNS OUT...
When I give it gas, it seems like it will die. It will pick back up when I take my foot off the pedal. I haven't held it long enough to see it will die for sure. This happens at 2, 2.5, and 3 turns out on the fuel screw. On stands, somewhere between 2.0-2.25 turns seems to give me the best idle and throttle response.
I can give it gas slowly and get going, but even opening the butterfly 1/2 way won't work.
With the choke on, it will move when I hit the throttle (an improvement, but not very smooth)
Like you guys mentioned, it seems like either an idle jet or carb angle issue.
I'm guessing here.
A.) Better on stands because less load needs less fuel? Current jetting gives enough fuel to raise the RPM of the engine with no load, but under load the pilot circuit struggles???
Increase/clean Pilot Jet?
B.) Better off the line with choke on because the current carb/jetting/cam/air filter/exhaust allows too much air, not enough fuel? Pilot Circuit struggles to provide enough gas to keep up with high air flow?
Increase/Clean pilot jet?
Try with Muffler on?
C) Better on stands because the angle of the carb is different compared to the ground?
The engine sits on swing arm that is already angled. This seems to compound with the angle of carb adapter. It is less significant with an occupant in the kart. Not exactly sure if or how this relates to my problem
Not sure how to test this, I might just try gravity feeding the carb and see what happens.
D.) Possible leak on intake side? Extra air causing lean mix?
Spray WD-40 somewhere around the carb adapter? when idling and see if RPMs increase??
It seems like a lean pilot circuit, which kinda makes sense to me. I guess I have a plan.
1.) Open valve cover and see what lash is at before next cold start
Open again after testing and see what lash is after, when hot.
Adjust if necessary.
2.) Spray WD-40 by carb/intake and see if RPM increases.
Re-gasket and seal intake side if leak if found.
3.) Try similar fuel adjustment trials starting at 2 turns out and go in this time.
3.) Put muffler on and try again.
If better with muffler, it means the pilot jet is too small.
Seems like a reasonable plan of attack.
---------- Post added at 02:40 PM ---------- Previous post was at 02:33 PM ----------
Also Hissing/slurping sound near carb/intake right after I killed the engine.
