AWWWW....SHUCKS! !. After viewing the video, I'm disappointed! It's just a video of your engine!
Two things: First, there's that axle sprocket wobble...really hard to tell from the video....(no good close-up of the hub) but it APPEARS that the sprocket is not mated well to the hub...and is the cause of the wobble....
Now...it could be bent...or just have something keeping it from bolting up flat...if you take it off and put it on something flat...any bends will be obvious and a hammer can fix that....conversely, checking run-out on the hub can be accomplished with any means necessary to locate a crayon just a hair off the surface and spinning the axle.
Sorry about the tease.
Still testing, trying to make sure I got at least a good idea of where I started.
I remember when I put the sprocket on, I had a issue with the set screw being being under one of the bolts. This some how prevented me from torquing the bolts in a correct fashion.
I was always aware of this, but laziness combined with eagerness to proceed kept me from investigating further.
---------- Post added at 01:50 PM ---------- Previous post was at 01:45 PM ----------
Reset valve clearance and see if it goes away....read your plug...easiest way to tell if it's lean...
(An intake valve not closing completely can cause a backfire.)
Good Idea!
---------- Post added at 02:13 PM ---------- Previous post was at 01:50 PM ----------
I have half a million concerns about leaks.
Will any Intake/Exhaust leak cause it to run lean?
-Could improper exhaust gasket cause it?
-Could any of the 3 or 4 connections on the intake side (head / adapter / carb / adapter / filter) cause it?
I thought I had the correct exhaust gasket from a previously returned engine, but when looking through some boxes of extra parts I have acquired (lol) I found a really beat up gasket that looks like it should be the exhaust gasket.
I think I used a papery gasket that I thought was correct. I found a much thicker metal foil looking gasket that seems more appropriate.
I've read of trouble with the seal between the head and the ARC Carb adapter.
I will still clean plug, check oil, rest lash, run at High RPM for a bit, kill the engine, and check the plug. I am back to the original plug now.
Time to order a whole new gasket set.
---------- Post added at 02:24 PM ---------- Previous post was at 02:13 PM ----------
Which Brings me back to Head Gasket Again! LOL
RK seems to know what he's is talking about.
I will get a thinner head gasket too. I believe the MLS one was 0.027" giving me 0.030" P2H clearance, but I've read MLS gaskets need an almost perfect mating surface.
Granted My Clay Model Piston checks out...
If I cannot find a shop to cut the head, I will probably try it my self. Mirror, glue, sandpaper, elbow grease, fury (lol). Don't know if MLS will be best for me. I'll look into the alternatives again.
---------- Post added at 02:26 PM ---------- Previous post was at 02:24 PM ----------
Thanks for all the Help! You are all the bestest!
---------- Post added at 02:41 PM ---------- Previous post was at 02:26 PM ----------
I found copper head gasket 0.021".
