Ok, Ok, Ok, This has to stop. I HATE FUN! NO MORE FUN HERE!
:backtotopic::lolgoku:
Drained Oil.
Replaced with 17 fl oz of full synthetic 10W-30.
Set valve lash to a number smaller than I care to admit on here.
Ultra Gray'ed the valve cover.
Set Ignition Coil Gap to 0.026"
Fixed Nuts on Ends of Bolts holding Tie Rods on (using terrible tack welds)
Tried to weld a drill bit as pedal stop but I suck..
To be continued.
Tuesday Night is date night and My first day off in two weeks.
Hotel Pool/HotTub Party!!!
Jrgunn5150
Rudderless
Was said drill bit actually steel, or HSS, or was it carbide or some type of coating over something other than steel?
:backtotopic:???
Everytime I get here the fun is over, and it is back to boring over my head engine garbally goop.
Ok now :backtotopic:
I was running late (like always), I found a bit I liked. Checked it with magnet. Not sure what type of bit it was. Ground the old stopper. Ground the drill bit.
I tried to weld drill bit to old stopper. Round to round.
It was difficult to clamp together.
The weld attempt was laughable.
I didn't have time to try again.
cavfire
auburn, georgia
Drained Oil.
To be continued.
Zero lash cold isn't unheard of. Lash will open up .002"-.003" at operating temp.
That's what I read and was hoping for. I won't call it zero, but I couldn't fit my 0.0016 gauge in there.
The actual lash setting was taught to me by a nice gentleman from the South. He said, and I quote, "Be precise as possible went setting that lash to exactly One Half of a C__t Hair!"
lol - it's pretty close to zero.
Well the First Cold Start since the oil change was not an easy one.
It took 3 minutes to get it fired up this morning. On previous test run, the probably unnecessary filter on the tank vent fell off. I tightened it on with a hose clamp. Maybe too tight. Unscrewing the gas cap seemed to help.
Boring video of me struggling to get it up... <<<<go ahead have at it, I just set the pins.....
https://www.youtube.com/watch?v=XzpNSsgGktU&feature=youtu.be
Ummmmm.....that YouTube link was to a sex video! JK....But when I clicked on it....it said it was "private" ....hope it's not YOUR privates!
---------- Post added at 12:03 PM ---------- Previous post was at 12:01 PM ----------
I rest my case!
Idle started around 1250 RPM then warmed up to 1750 RPM in about 5 minutes.
I struck oil, but not in a good Texas way. I think it's the crankcase cover. I'm going to have to take it off and have a looksie. During diagnostics, I opened and closed lots of stuff.
I'll order a new gasket, just to be safe. But in the mean time...
I'll use Ultra Gray, Cherrios, Copper Tan Sun Lotion Spray, DOUBLE MINT, and Fumunda Cheese!!!! No Leaks for Sure.
Still stock blue tipped Torque Converter Drive Unit garter springs (listed as 2100 RPM? maybe 2.2k)
Tested it out on jack stands. Wheels start to spin at 2100 RPM. Hooda Wooda Thought to Believe? Idle returns to 1750 RPM and wheels stop. (1:34 - 1:40)
6k in this video. Idle for first 0:40.
Not sure if its my thumb or if there's a flat spot in the power band???
Sprocket Wobbles, Chain may be loose, Exhaust looks bad, seats are dirty, tires are bald
https://www.youtube.com/watch?v=aPsPG6KjvlM&feature=youtu.be
---------- Post added at 12:43 PM ---------- Previous post was at 12:42 PM ----------
I rest my case!
I'll see if I can change it to public indecency. lol
Cool....December is still open on the 2016 Poboy Calendar!
AWWWW....SHUCKS! !. After viewing the video, I'm disappointed! It's just a video of your engine!
Two things: First, there's that axle sprocket wobble...really hard to tell from the video....(no good close-up of the hub) but it APPEARS that the sprocket is not mated well to the hub...and is the cause of the wobble....
Now...it could be bent...or just have something keeping it from bolting up flat...if you take it off and put it on something flat...any bends will be obvious and a hammer can fix that....conversely, checking run-out on the hub can be accomplished with any means necessary to locate a crayon just a hair off the surface and spinning the axle.
Secondly....Why bother with jackstands? (Those rear tires are so worn out....they would have just spun in place! ) (Just messin with ya on #2!)
Warm start.
Two pulls no choke, 1 pull choke... Videos are all G rated.
Tested how Idle, Clutch, and throttle response synced to turn the wheels. 350 RPM and uessing about 3/16 sec delay?
6120 RPM 1:54
EDIT: I Was Scared to go any higher on the RPMs.
https://www.youtube.com/watch?v=WL4KkwWVazU&feature=youtu.be
---------- Post added at 01:33 PM ---------- Previous post was at 01:17 PM ----------
Just guessing... based off the motion of the air filter, the back fire seems to be in the intake????
It seems to get worse as the engine warms up.
What does this tell me??
Too lean?
Reset valve clearance and see if it goes away....read your plug...easiest way to tell if it's lean...(or a bathroom scale....WAIT!!!! nevermind....I can tell from the video the bathroom scale isn't going to come up lean! LOL!)
(An intake valve not closing completely can cause a backfire.)
Sorry about the tease.
Still testing, trying to make sure I got at least a good idea of where I started.
I remember when I put the sprocket on, I had a issue with the set screw being being under one of the bolts. This some how prevented me from torquing the bolts in a correct fashion.
I was always aware of this, but laziness combined with eagerness to proceed kept me from investigating further.
---------- Post added at 01:50 PM ---------- Previous post was at 01:45 PM ----------
Good Idea!
---------- Post added at 02:13 PM ---------- Previous post was at 01:50 PM ----------
I have half a million concerns about leaks.
Will any Intake/Exhaust leak cause it to run lean?
-Could improper exhaust gasket cause it?
-Could any of the 3 or 4 connections on the intake side (head / adapter / carb / adapter / filter) cause it?
I thought I had the correct exhaust gasket from a previously returned engine, but when looking through some boxes of extra parts I have acquired (lol) I found a really beat up gasket that looks like it should be the exhaust gasket.
I think I used a papery gasket that I thought was correct. I found a much thicker metal foil looking gasket that seems more appropriate.
I've read of trouble with the seal between the head and the ARC Carb adapter.
I will still clean plug, check oil, rest lash, run at High RPM for a bit, kill the engine, and check the plug. I am back to the original plug now.
Time to order a whole new gasket set.
---------- Post added at 02:24 PM ---------- Previous post was at 02:13 PM ----------
Which Brings me back to Head Gasket Again! LOL
RK seems to know what he's is talking about.
I will get a thinner head gasket too. I believe the MLS one was 0.027" giving me 0.030" P2H clearance, but I've read MLS gaskets need an almost perfect mating surface.
Granted My Clay Model Piston checks out...
If I cannot find a shop to cut the head, I will probably try it my self. Mirror, glue, sandpaper, elbow grease, fury (lol). Don't know if MLS will be best for me. I'll look into the alternatives again.
---------- Post added at 02:26 PM ---------- Previous post was at 02:24 PM ----------
Thanks for all the Help! You are all the bestest!
---------- Post added at 02:41 PM ---------- Previous post was at 02:26 PM ----------
I found copper head gasket 0.021".
A request from YouTube as to how I set up the throttle.
Cable comes from front, under gas tank.
I bent and notched off some of the throttle plate so the cable didn't have to do this "^".
And then attached like this...
The bracket that holds the cable was rotated 90 degrees and the tab was bent so it fit over the edge of the plate. I cut off the other tab altogether.
