Or stuffed in a box waiting for the bell to ring. Sounds less depressing and more like WWF when I type it.
---------- Post added at 02:23 PM ---------- Previous post was at 01:42 PM ----------
Not much getting done today. By Tuesday I'll have the return line w/valve installed. I plan on using a Rubber Grommet in the top of the tank and feeding a few inches of hose in there.
Which brings me to my lunch date. Kid's got jokes! lol I'm going to be late. Lets go Blackhawks!
Here's the basic idea. Need to drill hole to fit Grommet. Will cut and position hoses once I find a spot where it is aesthetically pleasing.
I'm becoming mesmerized with the Medusa like bends of all the tubing.
I actually really like it!
Seems Fitting for a Predator!
Makes me want to paint the exhaust and clean up the outside. Everything needs a good wash.
---------- Post added at 05:35 PM ---------- Previous post was at 05:23 PM ----------
Should I add a fuel filter???
Yes add a fuel filter.
But now I see a pic of your complete installed engine and the Stock fuel tank location.
So why the fuel pump at all?
I wasn't sure where I was going to put the tank. After planning for Pulley, Alternator, and battery, I decided the stock location was best. When I asked the guy at ARC about gravity feeding the Carb, he said they don't gravity feed anything and couldn't offer advice on it.
---------- Post added at 05:58 PM ---------- Previous post was at 05:54 PM ----------
I already had the pump in the cart, but he helped sell it to me. lol
---------- Post added at 06:02 PM ---------- Previous post was at 05:58 PM ----------
If it gives me trouble, I can resort to "KISS" but I've heard fuel pumps alone can improve performance. This might be incorrect???
This says 1.5mm with pump and no fuel return.
I wonder if adding the return line allows you to use the 2.0 mm???
I dunno. Desertduler is pretty sharp. I'd assume he is right, maybe the return line is just a bandaid. but I dunno That thread is for a cr 2 stroke and DD uses 2 strokes and rotary's.
Just one more thing to look into.
Learn 1 thing, realize I don't understand another 10. Lol
Thanks and I'll see what I can find.
Glad I didn't rush my shopping list.
Maybe I can add more valves and tubes and add a pump bypass. Lol
Medusa is staying! Even if just for show! Lol
---------- Post added at 04:33 AM ---------- Previous post was at 04:07 AM ----------
I found this with Google images:
Pop off pressure values almost double when switching from 2.0 mm to 1.5 mm.
Example:
With 115g arm springs, pop off pressure is 32 psi with 2.0mm needle valve and 55psi with 1.5 mm needle valve.
With 65g arm springs, pop off pressure is 18 psi with 2.0 needle valve and 32 psi with 1.5mm eedle valve.
Link won't work.
Google:
mikuni needle and seat chart
Seems like I should be able to tune this with fuel return valve and get the 2.0mm needle valve to work by adjusting how much fuel goes back to the tank.
Thanks Chancer!
Please keep pointing me towards cool and helpful builds and threads and I'll try to just read and learn and not use my new Pirate skills.
Anything like drunk hillbillies doing backflips on minibikes with nitro is cool with me!
Jrgunn5150
Rudderless
I already drove my kart for hours and broke it. I fully expected spectacular video with American flag's gently blowing in the background and Bald Eagles exploding from your pipe in red white and blue here.
Now I wonder if I should monkey with my torque converter lol.
rk970
Coupeville, WA
Ya know, My motorcycle is 1108cc (modified Kawasaki 1000) makes 137hp at the rear wheel. It has a gravity feed fuel system.. 5/16" (8mm) fuel line from the tank petcock to the carbs.
If it was me.. I would try gravity feed first to see if you have any problems.
It takes about 11gal/hr(gasoline) flow to support approx 100hp or 23oz per minute. Say you have 20hp its 4.7oz per min..
What happened?
I'll have to find a bandana for when I DO ride it! And play the Rocky Sound Track in the back ground.
Jrgunn5150
Rudderless
What happened?
My performance was just lackluster, I never gave much thought to the torque converter as a tuning tool, I just rebuilt it and put the spring in the third hole for offroad lol.
I feel like I'm getting a near immediate shift into high, which makes it have a rubber band kind of take off,
https://www.youtube.com/watch?v=nZFvvGAT31Q
Only he with the Mirrored Shield can be the Perseus to my Medusa.
Lol
Ok I get. Gravity carb, gravity needle valve seat, stock tank location.
I should use gravity!!!!
Maybe I'll get a bigger tank and put it up front so you all will let me keep my beautiful tubes.
Jk, I'd rather not buy new needle valve assembly.
Gravity makes sense, but neither do I!!!
---------- Post added at 07:33 PM ---------- Previous post was at 07:22 PM ----------
I will will play with both gravity and the adjustable fuel return, since it is already set up. I'd prefer not to spend more money on smaller needle seat.
This is the fun stuff!
Jrgunn5150
Rudderless
That video thumbnail. That looks like a sweet jump if the middle part was dug out some. or a hill climb to test the karts abilities :D
I tried a few hill climbs, I have to carve like a dune lol. Probably because I'm far too big to be riding a go kart lol.
