26 lb springs, 5100 RPM? You could almost get away with stock springs at 5100 rpm. Why not 18 lb springs?
26lb is what was recommended from SmallEngineCams. I thought I needed the 26lb springs (even at 5100 RPM) because of the shape of the lobes on the Black Mamba Jr Cam. Is This not the case???? I'd like to use the lightest springs possible if Stiffer springs might rob low end power.
I ordered 18lb springs before, but never installed them.
The pic shows the 26lb "White" springs on top (about 1") and the 18lb springs on bottom (1.5"). Now I'm not sure if only one set is correct size, or both, or neither ???? For Hemi Predator 212cc.
If going for low end you don't want to port a lot just smooth up rough casting. Smaller arbs and smaller ports is what u want
This makes sense... From what I've read this far, at lower RPM Air Velocity is important and at higher RPMs Volume is more imortant.
---------- Post added at 01:23 PM ---------- Previous post was at 01:08 PM ----------
By the way, when I was watching your TC cleaning video.... I'm like this guy's voice would be great for audio books.:lolgoku: Anyway thanks for your help and thanks for putting together useful info for guys like me.
I should find this helpful. Once I find out what language it is written in
http://www.superchevy.com/how-to/95518-small-block-cylinder-head-porting/
Jk, it is in English. I guess I should buy a head to practice on. Ebay, junkyard, cemetery?
'To speed up the cutting procedure, we purchased an egg-shaped carbide cutter with a ½-inch head and a 2-inch shank. The plan was to have the author, with no prior porting experience, do the porting to illustrate the ease with which this could be accomplished. What you see here is exactly what the author created on his first attempt."
'McKenzie told us that our cutter would work best with a speed reducer, limiting operating speeds to 15,000 rpm. As we began porting, we realized that the new carbide cutter worked extremely fast, requiring us to constantly keep it moving under very light pressure."
"From the start, McKenzie made it clear that the goal is to create a smooth-flowing path for the air to travel across. Cylinder head porting is more about how well air flows through the port rather than port size."
It gets more detailed.
Pretty helpful
Keep in mind that small engines have slightly different dynamics of airflow than 8 cylinder heads....
This is because when 8 cylinders are tied together...the intake and exhaust runners become much longer which affects velocity as well as volume movement....the little guys just puff in and out....
That being said almost all that information is pertinent. However...I suggest you use the above search feature ....click advanced and then enter "Professional porting".
I did an Advanced search for "Professional porting" and scrolled through the other two threads (besides this one). Not sure where you are pointing me.
I was going off memory of a thread with that in the title....but I can't seem to locate it.
I did Google up"Predator 212 porting" and there's a YouTube video or two....
Did you watch the rest of this guy's videos? He cracks me up!
In one video he's got a fresh white lab coat on and talks about "Who invented dressing like a bum to work on an engine?" lol
"That's why my stuff goes faster than yours!" lol
Lapping new valves
Do I need to lap new valves???
Going to order 25mm stainless for exhaust and 27mm stainless for intake. I learned how to lap the valves on a OHV so I bought some lapping compound but not sure that it is needed or recommended with brand new valves.
It seems like I should do it, but have read mixed ideas.
---------- Post added at 02:57 PM ---------- Previous post was at 02:49 PM ----------
I can get a rental cylinder honing tool (if that is needed to be done, I'd like to try it) and rental piston ring compressor. No so lucky with Inch - pound torque wrench.
Is honing the cylinder something that should be done while the engine is apart, or only if it needs it?
gman3850
gilbert az
Only time u need to hone cylinder is if your are putting new rings in or if the cylinder wall is worn or damage
If you can see the crosshatch is good and no scars or scrapes that catch your nail you are fine.
As for lapping valves yes you need to lap. that way they will properly seal.
Jrgunn5150
Rudderless
Use the compound, get the suction cup thingy, lap away. I'm interested in your build, I didn't quite go full retard, but I really want to lol.
Some items I've been looking at:
25mm SS exhaust valve
http://www.arcracing.com/dj-1121-stainless-steel-intake-valve-
27mm SS intake valve
http://www.arcracing.com/dj-1127-int-valve-stainless-27mm-hp/
+0.020" Billet Connecting Rod
http://www.arcracing.com/6256-billet-rod-hf-predator-020-3-328/
Gasket Choice will depend on measurements and help from you guys
0.045" Fiber Head Gasket w/ Fire Ring
http://www.nrracing.com/product-p/2756fiberhg.htm
0.036" Multi Layer Steel Head Gasket
http://www.arcracing.com/dj-1310p-36-predator-head-gasket-036-70mm/
0.032" Copper Head Gasket
http://www.nrracing.com/product-p/predcopperhg.htm
So I'm expecting to find my piston (with stock connecting rod) sitting 0.015" to 0.020" in the hole. Using a +0.020" Connecting Rod, I should be anywhere from flush to 0.005" Popout.
Do the benefits of the thicker FIRE RING gasket outweigh the increase in performance from using a slightly smaller (0.036 vs 0.045) gasket? SEE Question Below.
More specifically..
If you had 0.005" Popout (needing a gasket of at least 0.035") would you pick the Fire Ring gasket (0.045") or the 0.036"????
Lastly.... (I know, sorry)
What is better? Longer Rod w/ thick gasket or Shorter Rod w/ thin gasket? EDITED CAUSE I'M STUPID
---------- Post added at 06:10 PM ---------- Previous post was at 06:05 PM ----------
I saw people using a drill on low speed and a piece of tubing to connect a driver bit to the valve (for OHV). Using a little pulling force, working the valve in and out, forward and reverse. Seems too easy for me to mess up using power tools, so I'll probably use the suction cup (they'll be new anyway)
From pictures I see online, the hemi head doesn't look that bad. I couldn't see anything that looked terrible, but didn't get a close look and don't exactly what to look for yet
Jrgunn5150
Rudderless
Ok, I'm pulling from my 1:1 racecar experience here, but of the gasket's you have listed, I would choose the .036 MLS (Multi-Layered Steel). The is the newest, most durable gasket technology. ALthough on these engines, the leaking issues associated with copper are nonexistent, since there is no water.
Fire rings, on a fullsize anyway, require a receiver groove be machined into the head or block, or both to accept them.
I would use the .020 rod in conjunction with the .036 gasket, the Hemi head looks to be begging for additional "Quench" and would make good use of it, I think.
Thanks, Perfect!! This helps a great deal!
---------- Post added at 06:41 PM ---------- Previous post was at 06:33 PM ----------
and these retainers/keepers
http://www.arcracing.com/dj-1047-retainer-kit-valve-hd-w-keeper/
and lash caps
http://www.arcracing.com/dj-1051-high-performance-lash-cap/
Finding this site very helpful. Not for small engine specifically, but it is helping me understand the concepts, tools, prodecures... Tons of info (too much), most of which is only slightly over my head.
http://www.musclecardiy.com/category/cylinder-heads/
and good tips for using die grinders / carbide burrs here:
http://www.hobartwelders.com/weldtalk/archive/index.php/t-40470.html
"My $.02:
I bought my first carbide burr about 12 years ago when I wanted to port the heads on my a SBC I was building. I also had a Mac tools die grinder. I still have that burr today and it cuts 10 times better than any of the other 10 I've aquired over the years....even though it's missing half it's teeth.
Chatter...makes teeth break off of burrs. Everyone likes the Harbor Freight die grinders cuz they're cheap, but the bearings suck..loose bearings cause chatter. Use your HF grinders with sander rolls or abrasives that aren't affected much by chatter, get one good die grinder for use with the burrs....not only will the work turn out better, the burr will last **** near forever.
You can use a standard carbide burr on aluminum...keep a tub of cheap grease nearby...I like the white lithium stuff..dip the burr every 30 seconds or so and it won't load up....if it does load up, dip it and go at it again and it will clear itself.....or you could buy the ones designed for aluminum...but that's no fun.:D
Burrs are for heavy stock removal, stones are for finishing and cleaning up the surface you've previously "burred".
The burrs that look like a teardrop or semi-rounded christmas tree cut lots faster than straight or tapered burrs because you have less teeth in the cut at any given point due to the shape, so the one tooth gets more pressure applied...which carbide likes, and cuts faster. Using insuficient pressure against the cutter destroys carbides in a hurry."
Progress is slow because of this....
Too much fun to tear it down yet.
Jrgunn5150
Rudderless
That's why I haven't gone nuts lol. First I want it running, (it is now), then moving (waiting on driven rebuild kit), then maybe tires, then I'll go nuts lol.
With my lack of experience, who knows if I'll ever get it running again once I take it apart again. Lol. I'm getting impatient. Tomorrow I'll get a video of me ripping up the field across the street and then I'll see if I can start tear down before work. Plan on getting lots of pics and videos of this
---------- Post added at 11:24 PM ---------- Previous post was at 10:56 PM ----------
Looks like you got shot with a S#IT gun through a screen door.
when a stripper has irritable bowels.... Notice the sh%t eating grin
---------- Post added at 11:47 PM ---------- Previous post was at 11:24 PM ----------
Ok got me some more stuff.
80 grit rolls
http://www.eastwood.com/engine-port...e=&network=g&gclid=CI3FpcL0xssCFQYIaQodWYUKPQ
And this
Carbide burr set
http://www.eastwood.com/8pc-dual-cut-carbide-burr-set-1-4inch-shank.html
I didn't get the Aluminum/Wood carbide burrs, but got the cross cut set
Abrasive Cylinders / Tapers and Double Cut Carbide Burrs
And Here they are:
(20) 80 grit tapers and (20) 80 grit cylinders.
(2) 4" cartridge roll mandrel (1/4" shank)
(2) 6" cartridge roll mandrel (1/4" shank)
Burrs' working surface diameter ranges from 1/4" to maybe 5/8"
About 2-3" in total length
1/4" shank
