Found a Honda G200 engine ...
Flat screen TVs work great because you can watch you're favorite shows at the same time so you don't get bored. :thumbsup: Windows also work good also, just make sure there is something interesting to watch out side. :lolgoku:
:useless:
Lucky7
AB, Canada
:useless:
:funnypost::lolgoku: Thanks. How long approx should I be sanding the head for and what about the actual cylinder head. The part that the piston sits in. Do I have to sand that.
Until it is flat and it will work on any flat engine surface as long as you get a big enough piece of sandpaper. :thumbsup:
:useless:
But his isn't a GX...
Yes, we know; my post was based on this:
Okay guys , a question :
Im looking for a air filter bracket / adapter , and no wonders , due to how old the G series is ( or this engine in particular ) , i havent been able to find any ..
Or at least , i havent found the exact measuers of the GX200 carburetor intake , tho i did measure mine
I was merely stating that the two are interchangable...
NewbCarter
Solin , Croatia
Here it is , finally done ;)
NewbCarter
Solin , Croatia
Some more ..
NewbCarter
Solin , Croatia
And more ... and on the last pictures , you can see the throttle return spring bracket i fabricated out of the old throttle assembly , and welded that to the exhaust .
Also gonna put up a video of it running ...
NewbCarter
Solin , Croatia
Tho have to fine tune it once the exhaust is done and the air filter on...
Seems to be running lean ... bigger jet needed since the flow is much less restrictive ?
