Thats the remainder of the pump housing , will be able to remove it later ...
Be aware that a lot of water pump engines have a tapered shaft, making them unsuitable for use on a go kart...
And checked , its not a redux box , its just the governor housing i guess , because you can see in picture #3 , there is the second filler cap , and the governor arm sticking thru the housing above it ...
No, that's just the sump; as explained above, these engines have two oil fillers...
The governor is located in the main internal, bottom end cavity of the engine, otherwise known as "the sump", & runs directly off the crankshaft...
