You need to run the engine long enough to get completely warmed up and rev the engine up to vacate the excessive fuel that is puddled in the crankcases out of the engine so then you can properly set the air fuel mixture screws both high and low, that engine is loaded up with fuel and is "blubbering" or "four stroking" when the throttle is opened up, it would be best to be able to put the engine under a load to get it to clean out and then set the carburetor mixture screws, you will not crack a piston ring running your engine with those short exhaust pipes on the engine that is not true! but I would make an exhaust system similar in design of a two cylinder snowmobile exhaust not like a four stroke exhaust system two stroke engines are very sensitive to exhaust design and a four stroke exhaust is the complete wrong design for a two cycle engine.
