Desertduler
- Messages
- 1,736
- Reaction score
- 6
I will be watching your build, don't give up!
It's not over yet, you still have over a month to go &, remember, it's not about cosmetics, it about mechanicals, as long as it goes, stops & the engine can be killed, all from the drivers seat without touching the engine, it qualifies...
How about posting a video to let me hear the engine, maybe I can help you.
Also take a picture of the carburetor mixture screws.Ok I will tomorrow it's raining outside right now, but I'm pretty sure it's maybe the timing maybe the vibration of the motor loosen the armature plate or something because it sounds like its misfiring because the pops are spaced out, not as close together, and if it helps as I turn the low speed idle screw it idles slightly better, but I'll upload the video to tomorrow so you can see for yourself.thanks
Was the spring the same color as the old one? because some kits come with different rate springs and you should replace the spring with the same rated tension spring which is color coded so the carburetor has the correct pop off pressure per application and fuel curve.Yes it was leveled with the body and I did change the spring
