Desertduler
- Messages
- 1,736
- Reaction score
- 14
Working on the pedals this morning,here are the components that I am using as pedal mounts and pivots. I have machined some 6061 aluminium post bearings for the pedals and they go on to the grade 8 3/8 bolts that I welded to the inside of the frame right in front of the heel bar.I use flat washers on both sides of the pedal tubing as thrust washers,the aluminium post bearings are machined slightly wider than the tubing so the pedals have a little side clearance.
