Desertduler
- Messages
- 1,736
- Reaction score
- 13
https://www.motionindustries.com/productDetail.jsp?sku=00159336
Something like this.
idler sprockets...
http://www.martinsprocket.com/docs/default-source/catalog-sprockets/idler-sprockets.pdf?sfvrsn=8
Oh in case you missed my edit..
allow me to ask again..
Bret, how about a split LDPE bushing instead?
and some locking collars to prevent lateral movement,
then a 'pulling' spring on the end of the dipstick....
maybe with several small grooves or holes to adjust the lever (and tension)
The plot thickens! OH!
It will be up to you Kelly as to what direction you want to go.
Gnarley. Totally cool idea.
I don't have any little #35 gears but I do have numerous Noram Clutch drives/drums I don't use. If one of these was introduced, they have needle/roller bearings pressed into them. The ID is larger than 5/8 but shouldn't be a problem. What's the ID of the wrist pin hole?
Shave off the drum portion leaving just the gear and it might be a bolt on solution, period!
Route Like picture 1?
Lovely.
Anyone watching that may remember what we're doing there is: 2 Briggs Flatties, 2 chains, to clutches, two rear gears. Engine number one has an 18T up front and a 52T in the rear. Once engine 1 gets it up to about 45 ish...we wind up engine 2 and let off Engine 1... where it can take over with a 20T up front and a 37T in the rear... (yes, I"ll have a helmet on, thank you)
Of course, special wheels will be on this one and I have just the answer. Super Hard, super Skinny DURO race tires. Yea. We'll mounth the go pro lookin out the back right by a wheel for this one.
More of its initial setup is here: http://www.diygokarts.com/vb/showpost.php?p=319670&postcount=1073
Anyone got a spare Briggs pipe like the one I have? I"ll trade ya something cool for it!
Please allow me to ask what's been done to the engines...
since mathematically 5hp will not be sufficient to even scratch the 50mph mark.
"Goof Off"???????.....Oh....that's right....this is a "family friendly " forum......we can't call you a "F"-up......![]()
I see two engines inline rather than side by side in a previous post, perhaps it's getting a little aero work beyond your average kart
Although I do have to ask, if you're going for top speed why gear differently and run the engines separately? Two low ratio engines will likely do as well as one high ratio on the low end... and two low ratio engines will definitely do better than one low ratio engine on the top end... then you won't have to fiddle with running them separately either.
do not get confused by the numbers...
it's actually a fraction..
1/6 (as in 6:1) is less than 1/3 (as in 3:1)
Ratios don't flip around like that... I can't think of a good example, but here:
http://en.wikipedia.org/wiki/Ratio#Notation_and_terminology
A:B = A/B. So 6:1 = 6/1
has spoken
