Desertduler
- Messages
- 1,736
- Reaction score
- 13
I am going to build a shifter kart also in the near future and I am going to use a KTM 525 four stroke engine that I have that I have turned into a 540.
That is a JLO Rockwell L252 brand new with modifications by me.I like the little one on the end..... Gotta get me one.....![]()
Uhh, question...... What is it?![]()
In its stock form it is rated about 10.5 hp @ 5500 rpm I have altered the squish band and I have done port work to the cylinder and I bored out the intake manifold and I have had a 30mm Mikuni on it and I have test ran it on my kart and it pulls real hard off the bottom and pulls clean out to its higher rpm range I was shocked how hard this engine pulls it would kill any of my other engines off the bottom end but it vibrates at a low rpm because of the way the engine is balanced but when it spools up to the higher rpm range it smooths right out but I could change the balance of the crankshaft but then it would vibrate in the higher rpm range and that it the way it is with single cylinder engines.If I do use it I will come up with some rubber mounts to help dampen some of the vibrations that the engine develops down at low rpm levels.Yeah, I figured you tinkered with it.....
What kinda power does that put out, and what's the rpm range? I'm assuming 2 stroke, I love that WAAAAAAaAA sound...... It's intimidating to regular kart riders.....![]()
Yes indeed that KM24 Wankel is a good one and turbine smooth running!A real rare bird now days!..it's always funny how that "J" issue is sticking to everyones mind...
it's ILO
Anywhoo.. the center one.. edgy wankel.. couldn't get more Bauhaus than that !
Hey thanks! I am just having fun building these things and experimenting with different engines and configurations and state of tune.Man, that is some first class work! Beautiful.
That's nice!![]()
