Safe spindles for 60mph+
Smcgillis10
Rock springs, Wyoming
Once I get the main part of y spindles made I'll show you not I'll show them after I get them mocked up. The idea I have for the strength at the point where they connect is welding the bolt head onto the spindle and placing a steel bushing over the bolt and make some gussets and well it onto the spindle and the bolt shank.
I just hope you weld better than you type.....:lolgoku:
fowler
Bullsbrook West Aus
how id do it
personally
3/4 bar
drill and tap holes in each end to take 1/2 inch bolts
drill a hole right though the middle to insert your spindle bolt
weld it both sides
brace it up
also brace the steering arm
and brace to the spindle
then use the heim joints like in your pm with the wekd in bungs for the tube
theres also pics of the spindles from my buggy
that was made to do 60mph on dirt and sand
