Any updates?! Waiting on your pilot's licence? Can't find an un-interupted strip of pavement long enough?
I assume you mean my 'creation'?
I just today fixed some symmetry problems I encountered with mounts.
It seems my mounts were not as identical as first thought. I did not realize how critical dimensions are in regard to mounting twins.
Chain had correct amount of tension on left side but when I mounted chain on right side found it to be too tight and could not adjust it out.
Fixed that problem and finally got engine parts to complete second engine rebuild (rings, piston, rod bearing liners).
All I really need to do now is connect throttle linkage which should make kart completely operational sometime this week.
After all bugs are worked out, kart will be completely disassembled-painted (canary yellow or pink?)-then reassembled.
Official first test run won't take place for at least another few weeks.
I will attempt to post pics of progress tomorrow.
