rvndraju
engine mounts
Engine mounts are welded on to the chassis and ready for the engine to be mounted.
The mounts on the engine and transmission is of OEM . Those mounts are designed perfectly to with stand the heavy vibrations on this diesel engine.
And this the video https://www.youtube.com/watch?v=dU8TgEmPjxIwhen we started the engine for the 1st time after mounting it on the chassis. We where actually worried about the heavy vibrations but engine mounts did the job perfectly and it run pretty good
so we decided to go for DOUBLE WISHBONE type. finally we designed a lower H arm & upper I arm setup.
